RJ Hamner
I Don't Think This Is What They Had In Mind When They Said Put Some Spark In Your Life
RJ Hamner
I had wired the tractor according to the wiring diagram (I thought) and have been waiting on some parts to finish.
Everything was ready to go except the ground wire connected to the battery.
As I was looking at my handy work I thought that the ground wire would look better if I moved it to the other side of the fuel line.
In the process of moving the wire it touched the negative post on the battery......ZAP SPARKS!!!:scared-eek:
Got out the diagram (see photo) and retraced the wires from the regulator (see next photo) to the switches in the dash (see last photo)
Everything looked like it is where it is supposed to be.
The only thing that I am not 100% sure of is the wire that comes out the bottom of the regulator and to which terminal on the starter/generator (hard to see in the picture, it's on the right terminal)
I thought I had it on the correct terminal. That wire does not appear on the wiring diagram.
Could that be the problem? or is there something I missed??
Will appreciate any and all help
Bob
pfrederi
Your S/G and regulator are wired correctly.  The wire from the terminal under the regulator to the A on the genny doesn't show on WH wire diagrams it is a Kohler part...\
Edit How is your solenoid hooked up??
EDIT 2  Your wires are way to light.  The wire from the switch (S Start terminal) to the A terminal on the genny should at a minimum be 6ga Same with Battery+ to switch
Edit 3  The idiot light it is the correct type?  The socket is not grounded to the dash.  Only connectivity is S and I terminals...
Edit 4  Assuming ignition switch was off sparking may have been caused by a faulty cutout in the regulator.(Cutout  breaks connection with battery when genny isn't putting out)  Was it working OK in the past or did the battery go dead a lot.
Edited by pfrederi
squonk
I agree with Paul. If there is no solenoid the wire powering you switch and the wire to the generator from it need to be at least #6. I did a test on my engine stand when I was testing out some starter generators and inrush current was 82 amps and leveled out at 65 amps when cranking
squonk
I agree with Paul. If there is no solenoid the wire powering you switch and the wire to the generator from it need to be at least #6. I did a test on my engine stand when I was testing out some starter generators and inrush current was 82 amps and leveled out at 65 amps when cranking.
You could try unhooking the regulator and then connecting the ground. If the spark is gone the regulator is most likely faulty
pfrederi
I use this stuff for the Battery to switch and switch to genny.  It is a bit pricey but it is as flexible as wet noodle.  the stuff you get at most auto parts places is super stiff and hard to connect to the switch and route...
RJ Hamner
That is the way it was wired when I bought the tractor
This is my first time with a starter/generator tractor.  I know there should be a solenoid of sorts but nothing looks familiar that's why I went step by step with the diagram
I'm not really an electrician.  I have a few burn marks to prove it
I wondered about that.  Most of the diagrams list a wire size this one has nothing
Edit 3  The "idiot light" was only connected the way it shows in the diagram.  No third wire but wouldn't the light being "clamped" to the dash be enough?
Edit 4  The switch was in the OFF position (switch is new) when this happened.
When I bought the tractor I started it drove it around to make sure the hydro was OK and drove it onto the trailer.  Got home and drove it into the shed and then when I finished the prior project put it on the lift.  The battery seemed OK at the time
RJ Hamner
Who's catalogue/website is the?  I have some #6 but it a real bear to try to route and bend
RJ Hamner
I'm figuring on starting back to square one.  Looking at the diagram what gauge wire for the rest of the runs would you advise? Appreciate the help
squonk
#6 wire from the battery to the switch and from the switch to the generator. Also # 6 from the battery ground to a clean non painted spot on the frame or engine. You would be surprised how a ohm reading can go from mega-ohms on a connection of a bolt screwed into an engine block to ohms with the surface the cable touches cleaned off. Personally I use #4 wire when I can. 16 ga. minimum for everything else unless you WANT to use the lighter. Then # 12 if you do use the lighter. #16 can handle the lights.
pfrederi
https://www.mcmaster.com/#
You do  NOT want the idiot light to be grounded through the dash.  is it the original one?? Does it have two terminals on  it??
You do not need a solenoid as you have the heavy duty ignition switch but you do need the bigger wires.  Many guys want to put in a solenoid and it is certainly OK to do that .  I don't .. I like to live on the edge:P..It has worked for 50 + years I can deal with it.
Edited by pfrederi
RJ Hamner
The idiot light does have two wires that go to the switch .  As far as I know it is original (looks old enough to be)
The switch is new and is the correct part number.
Since it was you I had figured it was McMaster Carr.  10 ft each be delivered tomorrow
I am going with 10awg since I have a roll and the extra terminals are on order
Lets just hope the regulator is still good.  But I figure Murphy will raise his ugly head and the gremlins have destroyed the regulator while I wasn't looking
Thanks for the help
Bob
RJ Hamner
The brown truck dropped off the #6 wires today
You sure were not kidding about being limp as a noodle
Thanks for the info
Bob
RJ Hamner
Started the redo last night
Everything is either #6 or #10
Just have to run the new line to the coil
Did a "smoke check" and all is good:handgestures-thumbupright:
squonk
So now it's not throwing sparks?
RJ Hamner
Nope
Gregor
Maybe I am missing them, but I don't see any fuses anywhere. A fuse to the cigg lighter/lights would be good.
squonk
  On 9/25/2021 at 2:14 AM, RJ Hamner said:
Nope
So you never found the source of the original spark issue then?
RJ Hamner
Yes I did and I couldn’t believe I did it
I don’t know how many times I checked and rechecked things the first time. And then to do the exact same thing on the redo.
As luck would have it I caught it this time
I had the wires backwards on the ign and the st terminals.
I rewired a 416-8 without too much trouble and to screw up a simple as pie project this bad is beyond belief.
RJ Hamner
There is an inline fuse that’s on the outside of the dash.
  • Similar Content
    • RJ Hamner
      By RJ Hamner
      I noticed that the 876 was leaking trans fluid on the garage floor after i parked it.
      Went out the next day and cleaned up the spot and put a can under the hydro.
      Checked the next two days and nothing in the can.  So that told me it only leaks when its running
      Fired it up this afternoon and let it run and cycled the lift a few times
      Shut it off and checked all the hoses, filter and anything else I could see from the top
      Crawled underneath and found fluid dripping from the area circled in the photo
      If I replace the two parts noted on the photo is there a good chance that would fix the problem or are there bigger issues???
    • RJ Hamner
      By RJ Hamner
      One of the prior owners had added head and tail light to the tractor (876's did not have lights)
      I am getting down the the "short strokes" with the rebuild and trying to figure out the best place to add the circuit.
      My thoughts so far are to tap into the cigar lighter and run the wire over to the wafer switch (the PO did an outstanding job installing the switch to the dash panel)
      As most of the tractors that HAVE lights use a fuse in the circuit and I have been thinking of putting the fuse between the cigar lighter and the wafer switch.
      YES/NO??? Other ideas?
      When I disassembled the tractor I know that there was no fuse and I am not real sure about wires
       (I wasn't paying that much attention to the wires as I had the diagram and didn't realize then that the 876 didn't have lights)
    • RJ Hamner
      By RJ Hamner
      I found this "field modification" (origin unknown). The dark square that has been wired to the rod is lead that weighs about a pound and a half.
      the 876 doesen't have the friction parts of the later models so I am wondering if this was/is an attempt to dampen the movement of the forward/reverse lever?!?
      Any ideas??
      Bob
    • admin
      By admin-(Admin)
      1 page 187.26KB
      Dated January 1966
      5409 nylon bushing replaced by 6254 bronze bushing
      1966 model 876 - 6254 bronze bushing factory installed after serial 193056
      1966 model 1076 - 6254 bronze bushing factory installed after serial 214071
      1966 model 1276 - 6254 bronze bushing factory installed after serial 205328
    • Jrblanke
      By Jrblanke
      Hey guys,
      I logged on yesterday for the first time in several months and was inspired by Dells68 and Crazywheelhorseman to post my find from last summer.
      Short story:
       I bought an 876 off of craigslist a couple weeks after coming home from the WHCC show last year. My 1st child came a little early, so I stuck the tractor in the shed and haven’t touched it since. Don’t have plans to touch it for now, but I’m glad I bought it!
      Long story:
       I went to the wheel horse show in PA last year and managed to hold off on buying a short frame that I was really jonesing for. There were several there, but Richard’s 857 with the dual wheels was really calling my name. Anyways, I held off because my wife was about 7.5 months pregnant and it wasn’t the responsible thing to do. After all, this was going to be my last WHCC show for a little bit, and I had already sold my other 3 short frames and a gravely walk behind in the spirit “growing up”. Well folks, It only took 2 weeks. While surfing craigslist on my lunch break an ad popped up for an 876 in Richmond, VA. There were no pictures, but it said that it had original paint and ran when it was last parked in the storage shed 10 years ago. The only implement it came with was a disc set. Not sure what brand it was.  The price was $225 for everything, so I figured that was good enough to take the gamble.
      I checked the oil and tightened the alternator belt on the ol’ horse hauler (1984 toyota pickup) and headed north…well started to head north….I didn’t get but about 2 miles down the road and noticed the truck was running a little hot. What? How could this be? It’s a Toyota, that’s not supposed to happen. I thought, eh, “It’s all highway, I’m sure it will be fine.” Stupid. This is what happens when you have your mind set on a wheel horse. I mean, I’ve built a couple different chevy motors for my project vehicles. I work at a transmission manufacturer. I’m not new when it comes to motors/cars/maintenance. And when it comes to overheating, I knew with all of my being that it should be addressed very soon. bad bad things might result if an over heating problem is not addressed SOON. Clearly, I was not thinking rationally. So anyways, like I said, I headed north.
      It was an uneventful 2.5 hour trip up there until I got off on the exit where the WH was located. The temperature needle creeped closer and closer to the red line and as soon as I pulled into the guys neighborhood I cut the engine and coasted to his driveway. I thought, no big deal, I’ll get this thing and head home.
      I was there for literally 30 seconds and the guy starts wheeling the tractor to my truck…whoa whoa whoa…wait a second, let me at least pop the hood before we load it up. It definitely was not what I imagined. The seat was torn, the choke and throttle cables were frozen, it didn't run (which I knew going up there), fluid was leaking from the axles, and to top it all off, one of the sidewalls on the rear tire blew as he was rolling it towards my truck. After talking for a few minutes, it was clear that he wasn’t coming much off the price. More worried about actually making it home, I decided to just pay him and get the heck out of there.
      The truck started fine, and I was able to get on the highway before it got into the red.  I plugged in my address (well, what I thought was my address) and headed….north… Fortunately, because I’m so smart, I realized that I was driving north. Now I’m not the brightest cookie in the jar, but I know that if I had just driven 2.5 hours north, I needed to at least go 2.5 hours south. After realizing the GPS was going to my exact address, just in a different state, I corrected the issue and turned towards home. About the time I got the truck turned around, the battery light came on…. Great…
      OK, no big deal. I knew the belt was on the fritz when I started this trip, so I came prepared with the tools. By this time it was about 8:45pm and I knew time was running out if I wanted to make it to the auto parts store before they closed. So I picked the closest parts store to the highway and headed that direction. I arrived at autozone around 9:00 (they close at 9:30) and I popped the hood. Much to my dismay, the alternator belt was intact. Awesome. Who’s Idea was it to drive this truck, knowing it needed maintenance, on a 6 hour round trip during the work week? Oh yeah… mine. Genius.
      Anyways, I head inside with my fingers crossed that they have an alternator. Of course they didn’t. The only alternator in town is 30 minutes in the other direction.  There was no way I was going to make it there before it closed. No problem, I have a plan B. My truck is carbureted and doesn’t have too many things that run off of electricity, so I’ll try to make it home on batteries. So I bought 2 batteries, a new belt (just in case), some coolant, a new thermostat, gasket sealer, and a bottle of water and headed out the door.
      I started the truck and got back on the highway. Only 140 miles to go. I called my wife and told her that I was going to turn my phone off because of course I didn’t bring a phone charger. At this point, I was so mad at myself, that she just told me to get home as safely and quickly as possible and she would see me when I got there. The truck battery that was in the truck lasted all the way to the house! I was amazed. The headlights didn’t dim but just a little bit, but by the end of the trip the electronic ignition was acting funny and the horn was really weak. I rolled in at about 12:15am and went straight to bed.
      So the moral of this story is: Don’t do stupid things.
      I am looking forward to getting it running and preserving the great patina! I have since sold the disc set for 75 bucks, so ended up having 145 in it (not counting gas, of course). Anyways, here are the pictures I took last summer.
