mort 24 #1 Posted September 14, 2021 What should the 5/8" lug nuts on a 300-400 Wheel Horse tractor be torqued at? What grade of bolt are they? Thanks, Mort Share this post Link to post Share on other sites
8ntruck 7,256 #2 Posted September 14, 2021 (edited) I would recommend 80 lb-ft. Usually, the lug bolts are around grade 8. Check the bolt head. If it has 6 radial marks, it is grade 8. If it has 3 radial marks, it is grade 5. Edited September 14, 2021 by 8ntruck Share this post Link to post Share on other sites
roadapples 6,983 #3 Posted September 14, 2021 No idea what's correct, but I only torque mine to 50... 1 Share this post Link to post Share on other sites
kpinnc 13,106 #4 Posted September 14, 2021 In a 5 bolt hub, I've periodically rode around in the yard with the lugs as tight as I could get them with my bare hand- just if something needed moving. Never had one come loose yet. If one ever does, I hope someone is filming it... For normal use, 80 ft-lb I think was in the manual as 8ntruck already said. I would only torque them after ensuring the threads are cleaned and lubed up with anti-sieze. Share this post Link to post Share on other sites
Jeff-C175 7,203 #5 Posted September 14, 2021 51 minutes ago, kpinnc said: ensuring the threads are cleaned and lubed up with anti-sieze I didn't think lubing lug nut threads was recommended? I use 40 ft lb and never had one come loose. 1 Share this post Link to post Share on other sites
kpinnc 13,106 #6 Posted September 14, 2021 (edited) 8 minutes ago, Jeff-C175 said: I didn't think lubing lug nut threads was recommended? I use 40 ft lb and never had one come loose Maybe not. But I keep antisieze on all of mine and they haven't come loose in 15 years on a couple- but don't require an impact whench to break loose either. I'd think 40 foot lbs would be plenty on a single unweighted wheel. If your tires are filled and you have 50lb wheel weights and duallies? I think a more important thing would be equal and even torque in any wheel. Since my tractor wheels are hub centric and never exceed 10 mph, I feel relatively safe with 40-50 foot lbs. Lug centric wheels on a highway is another story. Edited September 14, 2021 by kpinnc 4 Share this post Link to post Share on other sites
8ntruck 7,256 #7 Posted September 14, 2021 80 lb-ft assumes that the threads on the lug nuts/studs/bolts are lightly lubricated - as in the way nuts and bolts are delivered from the factory. If you are adding things like anti-seize or oil to them, 40 to 50 lb-ft is better. Lubrication on threads increases the tension in the bolt or stud for a given amount of tightening torque - sometimes to the point of stud or bolt failure or wheel countersink damage. I spent my 40 year engineering career in the steel wheel industry learning trivia like this. 2 Share this post Link to post Share on other sites
Skipper 1,789 #8 Posted September 14, 2021 Hand torque till it feels right 3 3 Share this post Link to post Share on other sites
Pollack Pete 2,273 #9 Posted September 14, 2021 But just remember......"2 pieces is too tight " 7 Share this post Link to post Share on other sites
RandyLittrell 3,887 #10 Posted September 14, 2021 I have a really old worn out impact that tightens up just right, absolutely no idea what it torques to, but I have used it for all my vehicles and tractors for years. No broken lugs, no missing wheels! If you are using a hand socket and ratchet, you can tighten pretty hard and be fine. A lot of us grew up working on things and you just develop a "feel" for what is the right amount of tightness. Of course, my Dad used to get on me that I didn't know my own strength and I have twisted a few bolts off in my day!! I just got a new brushless dewalt 1/2" impact and I suspect I'm gonna mess a couple of things up until I figure out the proper amount of kachunka chunks!! RAndy 1 2 Share this post Link to post Share on other sites
953 nut 56,755 #11 Posted September 14, 2021 10 hours ago, mort said: What should the 5/8" lug nuts on a 300-400 Wheel Horse tractor be torqued at? Unless you have drilled and taped your hubs and rims for a much larger lug bolt you should be looking at torque specs for a 7/16" -20 fine thread bolt. They are grade 5 so according to the torque chart that would be 41 ft/lb of torque. 5 2 Share this post Link to post Share on other sites
Pullstart 63,542 #12 Posted September 14, 2021 1 hour ago, Pollack Pete said: But just remember......"2 pieces is too tight " Turn it in until it snaps, then back it off a quarter! 2 7 Share this post Link to post Share on other sites
kpinnc 13,106 #13 Posted September 14, 2021 1 hour ago, RandyLittrell said: proper amount of kachunka chunks!! Oh I'm using that one from now on... 1 2 Share this post Link to post Share on other sites
edgro 679 #14 Posted September 14, 2021 Gudentite 1 2 Share this post Link to post Share on other sites
WHX?? 49,923 #15 Posted September 16, 2021 On 9/14/2021 at 6:53 AM, pullstart said: Turn it in until it snaps, then back it off a quarter! Me thinks Pullhosen knows all about this.! On 9/14/2021 at 5:49 AM, RandyLittrell said: really old worn out impact that tightens up just right, absolutely no idea what it torques to, Question here guys is can you tighten up a nut with an unknown impact torque then see what it takes to loosen it up with a wrench. Would it give a guy an idea of what an air or cordless impact is doing? Guessing results might be skewed by air pressure or battery strength? 1 Share this post Link to post Share on other sites
squonk 41,941 #16 Posted September 16, 2021 7 minutes ago, WHX?? said: Me thinks Pullhosen knows all about this.! Question here guys is can you tighten up a nut with an unknown impact torque then see what it takes to loosen it up with a wrench. Would it give a guy an idea of what an air or cordless impact is doing? Guessing results might be skewed by air pressure or battery strength? You could loosen the nut with a torque wrench. What ever torque it takes to break it loose is the torque the impact put on it. Start the reading off low and slowly increase until the fastener breaks loose. 1 Share this post Link to post Share on other sites
Jeff-C175 7,203 #17 Posted September 16, 2021 30 minutes ago, squonk said: You could loosen the nut with a torque wrench. What ever torque it takes to break it loose is the torque the impact put on it. Start the reading off low and slowly increase until the fastener breaks loose. I've done something like this many years ago (more than 30) using a torque wrench in both directions and as I recall the 'break loose' torque was always higher than the tightening torque. It's been years since I did that and don't recall the details, but do recall that the longer the time between tight and loosen the higher the breakaway torque became (to a point). If you loosened it immediately, the torque to loosen was close, but always higher. I did not test with lubed parts though. 1 Share this post Link to post Share on other sites
RandyLittrell 3,887 #18 Posted September 16, 2021 42 minutes ago, squonk said: You could loosen the nut with a torque wrench. What ever torque it takes to break it loose is the torque the impact put on it. Start the reading off low and slowly increase until the fastener breaks loose. I would think you could do the inverse as well, increase torque till you tighten it further. Either way should get you in the ballpark. Maybe do both and average them out. Randy 1 1 Share this post Link to post Share on other sites
lynnmor 7,479 #19 Posted September 16, 2021 While you guys are cranking down on those grade 5 & grade 8 bolts, just remember that the threaded hole might be in a softer cast iron. 4 Share this post Link to post Share on other sites
squonk 41,941 #20 Posted September 16, 2021 Plus the lug is digging into the bevel on the wheel 1 Share this post Link to post Share on other sites
8ntruck 7,256 #21 Posted September 17, 2021 Test procedures for the steel wheel industry for recording lug nut torque at the end of the test call for reading the torque in the tightening direction. 2 1 Share this post Link to post Share on other sites
ranger 1,770 #22 Posted September 17, 2021 This may sound silly, but it also depends on how you use the torque wrench. I once watched an assembly line worker torquing a drive coupling plate to an engine flywheel, (VW 1.6ltr diesel). I had just finished replacing a damaged engine in a small road sweeper the company manufactures. Every bolt, (M8x1.25, 8.8 grade), snapped whilst being torqued. Getting new bolts from the production line, same results, torque wrench tested ok. Asked the worker if he had any problems? Answer “No”, I watched as he tightened a set of bolts. As each bolt appeared to become tight he gave a sharp ‘jerk’ with the wrench, rather than a steady pull, which caused it to ‘click’, supposedly indicating correct torque? Taking the torque wrench I then slowly ‘re-torqued’ each bolt, with a steady pull, each one snapped! A whole delivery of nuts and bolts were returned to the platers due to ‘Hydrogen Embrittlement’, ( incorrect after treatment following plating). I have often seen tyre fitters use a torque wrench the exact same way he did! Doug. 3 Share this post Link to post Share on other sites
8ntruck 7,256 #23 Posted September 17, 2021 @ranger I sure hope that the engines that were assembled with the faculty bolts were quarrenetened and corrected before getting out to the customer. Share this post Link to post Share on other sites
ranger 1,770 #24 Posted September 17, 2021 6 hours ago, 8ntruck said: @ranger I sure hope that the engines that were assembled with the faculty bolts were quarrenetened and corrected before getting out to the customer. I don’t know if any completed machines had power trains split to renew the suspect fasteners, I doubt it. I personally never had to rectify any failures out in the field. These particular bolts held the transmission coupling drive plate to the flywheel, imagine clutch pressure plate in a manual transmission setup. So no big upset if they failed, the machine in question was a 4 ton gross weight compact road sweeper with a max speed of 16mph. As an aside, we tried marketing these machines in the USA in the 1980s but could not guarantee that the machine could carry on working with minimal damage after being driven at max speed into a wall, or other ‘immovable’ object! (These questions were actually put to our sales personnel). Needless to say we didn’t continue to pursue this marketing opportunity! Doug. Share this post Link to post Share on other sites
Charbs152 254 #25 Posted September 22, 2021 A few ugga duggas on the 1/4 inch Milwaukee impact driver works Share this post Link to post Share on other sites
