wh1075 6 #1 Posted September 5, 2021 I have a recently aquired model 1055. It has the K241 with the starter/generator. Unfortunately the belt from the starter/generator is missing. I am not having any luck to find a wheel horse or Kohler part number to cross reference. I would like a belt that is the correct dimensions not just an oddball that is ill fitting. Any help is appreciated. Share this post Link to post Share on other sites
squonk 41,163 #2 Posted September 5, 2021 (edited) Napa 25-7345 Belt Angle: 37 Deg Belt Construction: Notched Belt Material: Ethylene (EPDM) Brand: NAPA Cord Material: Polyester Cross Section Designation of Belt: HC41 Effective Length: 34.59 in Manufacturer: Gates Notched Belt: Yes Number of Strands: 1 Outside Circumference: 35.35 in SDS Required: No Top Width: .41 UNSPSC: 26111801 V-Belt Type: V-Belt VMRS Code: 065-005-003 Weight: 0.17 Edited September 5, 2021 by squonk 1 1 Share this post Link to post Share on other sites
wh1075 6 #3 Posted September 5, 2021 Thanks, that is what I was looking for. I will track one down and go from there. Share this post Link to post Share on other sites
wallfish 17,015 #4 Posted September 5, 2021 41 minutes ago, squonk said: Napa 25-7345 Belt Angle: 37 Deg Belt Construction: Notched Belt Material: Ethylene (EPDM) Brand: NAPA Cord Material: Polyester Cross Section Designation of Belt: HC41 Effective Length: 34.59 in Manufacturer: Gates Notched Belt: Yes Number of Strands: 1 Outside Circumference: 35.35 in SDS Required: No Top Width: .41 UNSPSC: 26111801 V-Belt Type: V-Belt VMRS Code: 065-005-003 Weight: 0.17 More detail please! How much does it weigh in grams? 2 Share this post Link to post Share on other sites
squonk 41,163 #5 Posted September 5, 2021 15 minutes ago, wallfish said: More detail please! How much does it weigh in grams? 77 1 Share this post Link to post Share on other sites
