chev0545 234 #1 Posted September 5, 2021 just washed a 520 went to start it ran for a while.i noticed the 30amp fuse is melted.what's the fix? thanks Share this post Link to post Share on other sites
Handy Don 12,235 #2 Posted September 5, 2021 Change the fuse. Don't get water where it doesn't belong? Water + electricity = BAD Share this post Link to post Share on other sites
cleat 6,046 #3 Posted September 5, 2021 Ensure the fuse and the contacts in the fuse block are clean and tight. Put some di-electric grease (even white spray grease will work) on the fuse block contact area to help keep out water and prevent corrosion. The reason your fuse melted is due to a bad connection creating heat. 2 Share this post Link to post Share on other sites
