CCW 1,292 #1 Posted September 5, 2021 (edited) The scrapper blade on my 312-8's plow is worn on the outside corners from years of my father plowing the driveway. The top edge is still original. Can it be flipped over? ccwpost Edited September 5, 2021 by CCW Share this post Link to post Share on other sites
pfrederi 17,680 #2 Posted September 5, 2021 Yes!! 2 Share this post Link to post Share on other sites
stevasaurus 22,711 #3 Posted September 5, 2021 Absolutely !! In fact, I just happen to be doing that to my snow blade on my 857. Rather then mess with the old rusted bolts, I used a 4" grinder and made quick work of those old bolts. I also am changing from carriage bolts, I am using 1" X 3/8" stove bolts (they have a slot screw driver head) and Ny=Loc nuts. Orientate the scalp blade so the worn angle is high against the snow blade...or grind the sharp edge smooth. I'll take some pictures. Share this post Link to post Share on other sites
DougC 2,641 #4 Posted September 5, 2021 (edited) I flipped mine over a few years ago when I noticed how worn it was getting.Used my 1/2 inch impact and zipped off the nuts. The carriage bolts didn't spin at all so reused all the original fasteners. I should mention it was a 520H dozer blade. Edited September 5, 2021 by DougC Share this post Link to post Share on other sites
SylvanLakeWH 25,501 #5 Posted September 5, 2021 Yes Just did one of mine. Stainless bolts… Easy peasy… Share this post Link to post Share on other sites
CCW 1,292 #6 Posted September 5, 2021 Thanks all. The WH is not used for plowing snow, but I do need to move topsoil. Share this post Link to post Share on other sites
stevasaurus 22,711 #7 Posted September 6, 2021 Mine was rusty like yours. It would not let the snow go when pushing it. I used a 4" grinder with a wire wheel, cleaned off the rust, primed with Rust Oleum red primer. I used a 3" roller and Regal Red in a qt can along with a brush to paint. Painted the scraper flat black a flipped over. Pictures... 1 Share this post Link to post Share on other sites
