peter lena 8,588 #1 Posted September 5, 2021 found that , 2 , 12 " adjustable wrenches working on the same auger bend issue , in opposed directions , right on top of each other , deliver a very good easy result to a bend . just taking little bites on the area , increases your mechanical advantage . bouncing a hammer off of it is not good for any part of it . also using a specific chain lubricant on the auger drive , makes it work much easier , should be able to spin it up by hand at the belt mount area . just my own experience, pete 1 1 Share this post Link to post Share on other sites
johnnymag3 2,517 #2 Posted September 5, 2021 I use the same technique......never a hammer.... Bar and chain oil is my choice !!!! 1 Share this post Link to post Share on other sites
grinchsr 626 #3 Posted September 6, 2021 Sounds like someone is getting ready for winter. Share this post Link to post Share on other sites
peter lena 8,588 #4 Posted September 6, 2021 @grinchsr , living in CT you know how it goes , before you know it , morning frost , leaves , and the transition from mowing to plowing / blowing . with the weather changing , more plowing than blowing . never too soon to keep in touch with your stuff , as soon as it tells you something , get it done , pete Share this post Link to post Share on other sites
