James I
78350 42 inch RD Cutter Deck
James I
Hi, can anyone tell me if a 78350 42 inch RD Cutter Deck will attach to a WH 580xi model 73541. Looking for a replacement cutting deck which is out of production, the 98-5088. there are no measurements on any of the manuals so very difficult to tell if the 78350 will attach to the hydraulic lift system on the 580Xi. Any help gratefully received.
78350-_Parts_List.pdf Toro Wheelhorse Cutting deck-42-re-78353-78442.pdf Deck Pictures.docx
gwest_ca
The 78350 fits the 300, 400 and 500-Series of tractors.
Not the 5xi-Series which requires the 78353 model.
Assuming your tractor is a 518xi.
Garry
kpinnc
If it IS indeed a 580-xi, I want to hear it run!:D
James I
Ooops, i thought it was a 580 xi, but having loked at the tractor again i now realise that it is a 520xi, does that make a huge difference?
gwest_ca
No and still won't fit.
kpinnc
If such a thing existed, based on the model numbers- it would be an 80hp tractor.
Examples would be 518xi, 520xi, 522xi, and the 523xi- the last being a diesel. The last two digits specifed the hp rating on the xi series machines.
