dkg520
520 seat replacement
dkg520
Does anyone here know who sells a high back 520 seat replacement that has the correct bolt pattern?  I’ve tried Tractor Supply Store and Agri Supply and have had no luck.  Thanks.
cschannuth
@dclarke found one for his and he helped me find one for mine but for the life of me I can’t find where I ordered it. Knowing Denny, he’ll be able to tell us right away where we got our seats. I’m sure he’ll be along shortly to help you out.
peter lena
@dkg520 have 3 of these seats , bolt down w/h pattern , verify with seat bolt pattern  on lower edge of page , https://www.agrisupply.com/universal-tractor-seat/p/14119/?sid=asf10&eid=Easf10&zmam=77232640&zmas=1&zmac=1&zmap=14119&eid=gl020116&sid=google&gclid=CjwKCAjw4KyJBhAbEiwAaAQbE74jbKPkZZY59phqKCpbjvkNyQJOflJl79uXF_O66YL8LOJWfBhuihoCJiIQAvD_BwE  believe 7 1/2 x 7 , check your base mount set up . bolted right on , years now , no problems , pete
Lee1977
I think all the 500's have 7 1/2" wide by 8" deep bolt pattern. I know my 520 has that bolt pattern. I had a better set of seat tracks I was going to use but they would not fit.
dclarke
Craig, We got those seats from “turf seats.com”… I believe I used the “KM123” and you bought the “KM125”, which has a higher back….. I think. Lol….. dkg520, be sure to check the bolt pattern if you decide to order one of these but I’m pretty sure they are correct.
dkg520
Thank you
cschannuth
The 520’s are definitely an oddball bolt pattern. The seats Denny suggested have a pattern that matches.
dclarke
dkg, this will give you an idea of what that seat looks like on a 520.
dkg520
Is that the low back seat?
dclarke
Yes.. The KM123
cschannuth
Here’s the one Denny helped me find.  Like he said, I think it’s the same seat with a little bit higher back.8CB964FB-7C05-41FA-97E8-895FFBB848D2.jpeg.6eb0d1aa872ffcd5bffe6324d06dd7e3.jpeg
dkg520
Thanks again
lynnmor
Did you see my post under “seat cover” ?
