buchshot12000 21 #1 Posted August 29, 2021 So my starter got jamed up on the flywheel. When I got the covering off I noticed a tooth was missing. I got the starter gear free. but now it engages the flywheel, but the shaft spins inside the gear. does any one know where to get parts? or should i get a replacement? Share this post Link to post Share on other sites
953 nut 57,904 #2 Posted August 29, 2021 Try Jack's https://www.jackssmallengines.com/Products/KOHLER/Starter-Part/s Share this post Link to post Share on other sites
pfrederi 18,332 #3 Posted August 29, 2021 13 minutes ago, 953 nut said: Try Jack's https://www.jackssmallengines.com/Products/KOHLER/Starter-Part/s Not to go off topic but Jack's is now part of Northern Tool&Equipment 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,243 #4 Posted August 29, 2021 The Bendix drive is not fixed to the armature shaft. It slides in and out on a twisted spline. With the starter motor turning the spline forces the gear into the flywheel and when the flywheel speed exceeds the starter motor speed it forces the drive back to the starter. There has to be less expensive parts available from after-market suppliers. Here is a parts list to help you determine what you need. Let us know what you need so we can assist. Share this post Link to post Share on other sites
Jeff-C175 7,203 #5 Posted August 29, 2021 15 minutes ago, pfrederi said: Jack's I haven't been too keen on them for a while now. I have had issues with the past few orders. Mostly delays with shipping orders. I don't think they actually stock the parts themselves any longer. It seems to me that they are now 'drop shippers' and they don't have their supply channels set up very well yet. I think "Pat's Small Engines" might be a better bet. http://www.psep.biz/ Share this post Link to post Share on other sites
buchshot12000 21 #6 Posted August 29, 2021 Thanks all, Looks like the parts i need are no longer available, guess im going to find a replacement Share this post Link to post Share on other sites
Jeff-C175 7,203 #7 Posted August 29, 2021 (edited) 5 minutes ago, buchshot12000 said: parts i need are no longer available Not this drive gear assembly? (this may only be for the aftermarket starter that they sell?) Give Pat's a call... http://www.psep.biz/store/kohler_41_098_08-s_starter_motor.htm or check with Lincoln at A-Z Tractors, he can typically supply good used parts for purt near any WH need. https://a-ztractor.com/ <--calling on the phone is the best way! Edited August 29, 2021 by Jeff-C175 Share this post Link to post Share on other sites
squonk 42,534 #8 Posted August 29, 2021 Is this a starter that has the mounting holes in the top instead of the bottom? If so I have one here I'll let go cheep! Let me know. Share this post Link to post Share on other sites
buchshot12000 21 #9 Posted August 29, 2021 6 hours ago, Jeff-C175 said: Not this drive gear assembly? (this may only be for the aftermarket starter that they sell?) Give Pat's a call... http://www.psep.biz/store/kohler_41_098_08-s_starter_motor.htm or check with Lincoln at A-Z Tractors, he can typically supply good used parts for purt near any WH need. https://a-ztractor.com/ <--calling on the phone is the best way! ah i missed that, I need to pull it apart, and figure out why the gear engages, but the shaft just spins. Share this post Link to post Share on other sites
