Grease Fitting on one Deck Mandrel will NOT accept Lube
By
Rob R, in Implements and Attachments
Similar Content
By Horse Newbie
So for the last 5 to 6 months I have been working on getting my 1994 520H up to operating condition after buying it from a friends backyard a few years ago...now that I'm 99 percent done with the tractor I want/ have to get the 48 inch SD deck that came with it up to operating condition also.
As you can see by the pics I have a lot of work to do/ full restoration...I have a few questions before I get started...
1. Do the two wheels on the back of the deck control the cutting height ?
2. Where/ who is a good source for parts ?...I would like to go back with as much new parts as possible, but some of the pricier parts I will probably be willing to use used if my budget forces me to ( spindle are my main concern here).
As you may be able to see from the pics, the front center of the deck has been knocked back quite a ways ( looks like PO centered a concrete driveway/ sidewalk edge, or one stout survey corner stob.
Any suggestions about straightening the front edge would be greatly appreciated.
Also if any of you would have the center front wheel bracket on a junk deck that you would be willing to cut off and sell to me, it would be greatly appreciated.
By Horse Newbie
As you can see by the pics I have a lot of work to do/ full restoration...I have a few questions be fore I get started...
By woodbird007
Thinning Herd
2) 1974 B80 4 speeds
both run, one in need of rebuild
sd 36” deck
rd 36” deck
short frame dozer blade and mount
extra wheels and tires
$300 takes all
Kalamazoo, Mi area
By ToddA
I am Trying to find out if the Toro Deck 78353 will Fit On my 1975 C-160 Thanks For any Info Todd
By jay1
I just noticed that my b80 (1975) deck is rusting out. Is there a replacement deck that fits the B80. Tractor is in great shape--had the engine replace several years ago.
