Skipper
60" deck roller 682739 replacement?
Skipper
Anyone know of a good substitute for the 682739 deck roller for the 60", now they are NLA?
Would hate to have to drill the axles off and put some skinny JD stuff on there :-)
gwest_ca
68-2739 only shows up for the 1995 model 78390.
68-2730 shows for other years and more.
Wonder if there was a change or a typo entered the system?
Also used on Exmark
https://www.partstree.com/search/?type=part&term=1-603299
Garry
Skipper
Typical for me to fall on the one with a woopsi in it.
Thanks Garry. That made life a lot easier :-)
Edited by Skipper
daveoman1966
How long is the anti-scalp roller you need?  I have anywhere from about 4" wide to 12" wide..
Skipper
it's the side gauge wheels I need, but I might also be OK with a new set of the wide middle ones for the 60". Don't have the measurements for those on hand, but can take the deck off this weekend and measure. :-)
gwest_ca
Stens has a replacement and this is a Canadian dealer. I like the fact they most often have better descriptions.
Skipper
The middle rollers are 2.5 inch diameter, and 7 3/4 inch long. Center pin (axle) is .640 inch.
I assume you make them out of stock material. Could you custom make them?
Lee1977
I put Dogwood rollers with brass bushing in each end on my 48" deck back about 1990 I have only had to replace two. That was because the shaft came loose and I backed over them with the deck.
daveoman1966
I have 4 anti-scalp roilers...  2 are 5" long and 2 are just over 11" long.  All 4 are 3" diameter with 3/4" bore hole.  The bore hole is wallowed out to about 1" at the ends of some.  These are hard nylon and can be cut by any wood saw to desired length, of course.
Skipper
Thanks for the offer, but I will pass on it. The ones I have now are in better shape. I was hoping for some new ones, to do a full restoration of the deck.
Found some new ones from Stens, that only need to be shaved off a little, and have a 5/8 shaft installed.
