snowhound 105 #1 Posted August 19, 2021 I have had to ask for help with belt numbers and sizes a few times and am thankful for the quick and accurate information I received. My question is - Is there a belt size or belt number chart that I can download so I don't have to seek help when I need to replace a belt? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,243 #2 Posted August 19, 2021 The mower deck belts have some mistakes in the later years. As I come across them I make the correction in the description page for the parts lists for the deck involved. Some decks are used on both long frame and medium frame tractor models so there is a difference in the drive belts. There were also service bulletins issued that changed the recommended belt so have also included them in the parts list pages. Same with the tractor drive belts. 1 Share this post Link to post Share on other sites
Gary Ch 15 #3 Posted September 12, 2021 Would there be a deck (mule team) belt chart available? B 80 Model #1-0140. Thank You Gary Ch Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,243 #4 Posted September 15, 2021 On 9/12/2021 at 9:32 AM, Gary Ch said: Would there be a deck (mule team) belt chart available? B 80 Model #1-0140. Thank You Gary Ch The mower belt charts are listed by mower deck model number so you need to know what that is. If you search our Files using the tractor model you will find one with a D&A file. That is the tractor Details and Accessory list which lists the model numbers for each attachment. There are 2 models of 36" deck listed for the 1-0140 tractor. Then go to the belt chart. or Search the Files for your deck model. The belt numbers and sizes have been added to the file description page so you can get them without downloading anything. There are mistakes in the belt charts so doing this gave an opportunity to make corrections. Most mower decks share a parts manual with another size of deck so belts and blades are different. Only an original parts list will show what fits what. The online parts lists do not identify the deck sizes so 4 belts and 2 mower blades are listed with no model identification. If you search the Files using a belt part number all the mower decks that use that belt will come up. Share this post Link to post Share on other sites
