Gregor
Roto tiller
Gregor
I have a line on an MF 16, with snow plow, deck, and rototiller. I have never sen a rototiller on a tractor, and there is only 1 pic of the tractor, from the front. My question is, Does a rototiller require a 3 point hitch?  Thanks  Greg
Handy Don
Depends on the tractor.
On WH, it uses a Brinly-style sleeve hitch (sometimes referred to as a Cat 0). It is a single point mount.
pfrederi
You would have to know more about  it. Regular WHs use the rear axle mount as used for snow blades to mount the tiller and  the rock shaft and cable to lift it.  D series tillers use the Category Zero 3 pt hitch on the tractor.
Edited by pfrederi
