gcole 36 #1 Posted August 13, 2021 Hey guys, recently picked up a c195 package that came with a fairly decent 60” deck. The only bad is the deck needs blades and I’m having trouble locating the part numbers for said blades. Thanks in advance and any help is appreciated Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,033 #2 Posted August 13, 2021 or https://www.partstree.com/models/05-60sc01-toro-60-side-discharge-mower-deck-1982/ Share this post Link to post Share on other sites
peter lena 8,587 #3 Posted August 13, 2021 @gcole , using above blade information , will show you the exact size you need , take advantage and select the best TYPE of blade for your application . use the # for any brand blade , there are many types, another thing , is use a small fine flat file . with lubricating oil at touch up time , minimizes metal removal , and gives you a quick easy fresh edge , just my own experience , pete Share this post Link to post Share on other sites
WHX?? 48,799 #4 Posted August 13, 2021 Got any pics of that Super C? Share this post Link to post Share on other sites
peter lena 8,587 #5 Posted August 13, 2021 @gcole , quick look up availability ,https://www.google.com/search?q=wheel+horse+60+deck+blades&sxsrf=ALeKk01CQe2oRjeFnRR4CMqoCy-v8b9CxA%3A1628858692493&source=hp&ei=RGkWYfCwGsyt5NoP5LG44AI&iflsig=AINFCbYAAAAAYRZ3VE03dgFE97jwMoUtr34ILsfk2L0y&oq=wheel+horse+60"+&gs_lcp=Cgdnd3Mtd2l6EAEYAjIFCAAQgAQyCQgAEMkDEBYQHjIGCAAQFhAeMgYIABAWEB4yBggAEBYQHjIGCAAQFhAeMggIABAWEAoQHjoECCMQJzoLCAAQgAQQsQMQgwE6EQguEIAEELEDEIMBEMcBEKMCOggIABCABBCxAzoICC4QsQMQgwE6CAguEIAEELEDOggIABCABBDJAzoHCAAQgAQQCjoKCAAQgAQQsQMQClDCDli1U2DIamgAcAB4AYABogOIAYAWkgEJNS4yLjMuMy4xmAEAoAEB&sclient=gws-wiz , lots to choose from , pete Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,033 #6 Posted August 13, 2021 The 109077 3-blade set was only used on the 1982-1984 model 05-60SC01 mower deck. The later 60" decks used on the 520-Series tractors are different. Do not know the dimensions of the 109077 but will guess they are gold plated. https://www.psep1.biz/arinet.asp#/s/TO//109077//1/ More info on the 05-60SC01 deck https://www.wheelhorseforum.com/search/?q=05-60sc01&quick=1&type=downloads_file Garry Share this post Link to post Share on other sites
