uglyblue66 113 #1 Posted August 10, 2021 (edited) I thought I would at least get started here by posting pics of the 2 recent purchases and ask a few questions about the E-141 What I was hoping to learn,was if there is a troubleshooting guide for the E -141? I know GE has a service manual with trouble shooting flow charts and info.I did find a schematic and parts break downs which is a big help. BUT long story short,due to a accident related brain injury I am a bit slow to figure things out and pictures help. The B-145 is the same as a GE Electrac E-14 so my book on ge's will be a big help for it. But I think the E 141 is a bit more scarce and plus it is a single speed PM motor,easier to bring back. I have done some work to it since the photo was taken, Replaced rear tires with good used, new bearings in the motor,it runs, new pulleys.BUT having issues with belt length that is about to drive me nuts. Original belt is Almost perfect fit but stretched a bit. 60 inch belt to short,61 inch to long. Any who,I also got a really nice charger for the E 141 from a fellow in indiana. so that is covered. Now more questions. 1,what does the correct hitch look like on the back of the E 141? I would like to be able to put a brinley hitch on it perhaps but can't find a photo of that set up on a electric. 2, Will a push blade from a late 60's 854 horse fit this E 141? It has the Unidrive transmission so I am thinking it will. Ok, I will stop for now.:) thanks for letting me in the door! Edited August 10, 2021 by uglyblue66 4 4 Share this post Link to post Share on other sites
ZXT 2,401 #2 Posted August 10, 2021 (edited) Welcome to the forum! Not too many E tractors around here - always cool seeing another show up! I'm sure others will be along soon to give more info! Edited August 10, 2021 by ZXT Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,090 #3 Posted August 10, 2021 Welcome to Red Square. Gates replace the 107120 belt with a 6962 or Napa 5L620W which is 5/8" x 62" long. Wheel Horse lists the belt as 107120 - (B/5L x 61.35" or 5/8" x 61.35") Here is what we have on the E-141. The search results are mixed up so look through them all. Any with the OM is a D&A file. The "A" is the attachment list for that model year. https://www.wheelhorseforum.com/search/?q=e-141&quick=1&type=downloads_file Garry 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,090 #6 Posted August 10, 2021 11 hours ago, gwest_ca said: Here is what we have on the E-141. The search results are mixed up so look through them all. Any with the OM is a D&A file. The "A" is the attachment list for that model year. https://www.wheelhorseforum.com/search/?q=e-141&quick=1&type=downloads_file Garry Linked the 8-1570 or 81570 and 07-30EC01 charger for the E-141 to tractor files above. Share this post Link to post Share on other sites
uglyblue66 113 #7 Posted August 10, 2021 11 hours ago, gwest_ca said: Welcome to Red Square. Gates replace the 107120 belt with a 6962 or Napa 5L620W which is 5/8" x 62" long. Wheel Horse lists the belt as 107120 - (B/5L x 61.35" or 5/8" x 61.35") Here is what we have on the E-141. The search results are mixed up so look through them all. Any with the OM is a D&A file. The "A" is the attachment list for that model year. https://www.wheelhorseforum.com/search/?q=e-141&quick=1&type=downloads_file Garry So it is a oddball! Oh boy fun fun fun. 1 Share this post Link to post Share on other sites
Mike in NC 341 #8 Posted August 10, 2021 Welcome Uglyblue!! Glad you joined! The guys around here will be able to help you! 1 Share this post Link to post Share on other sites
uglyblue66 113 #10 Posted August 10, 2021 (edited) Well thank yawl for the welcome. here is a couple pics of the E 141.. 1 of it's "brain" as it is called by Wheel Horse, exposed and the second 1 of the 62 inch belt and new pulleys. a 61 inch belt is to tight to function and would not slip.The original old belt is obviously a closer fit but is old. I have tried to figure out how to make this work correctly,and every change makes for a chain reaction.I am thinking a slightly smaller drive pulley or trans pulley might make it work a bit better but? Any ideas? Edited August 10, 2021 by uglyblue66 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,090 #11 Posted August 11, 2021 That belt is too loose to drive properly. Perhaps the pedal return spring on the other side is weak and not tensioning the belt properly. In order for the transmission pulley to stop so you can shift gears the belt guard must be on the tractor. The guard forces the pedal down belt slack to the motor pulley so it can slip. Garry Share this post Link to post Share on other sites
uglyblue66 113 #12 Posted August 11, 2021 (edited) 28 minutes ago, gwest_ca said: That belt is too loose to drive properly. Perhaps the pedal return spring on the other side is weak and not tensioning the belt properly. In order for the transmission pulley to stop so you can shift gears the belt guard must be on the tractor. The guard forces the pedal down belt slack to the motor pulley so it can slip. Garry I will put the belt guard back on but for the pics and for the sake of showing my issue,I left it off. The light colored idler pulley is the clutched pulley and even using my hand to force it back a bit more,it actually will get looser instead of tighter. the spring is pulling back as far as it can.I thought about putting a stronger 1 on until I worked it by hand and it did not tighten the 62 inch belt. Just a weird issue. The pulleys are the exact same size as the 1 's removed,they were all rusted and damaged beyond use.Amazing what around a 1/2 inch will do to a system. The 61 inch belt I got in the mail yesterday off ebay is to tight. Sliding the electric drive motor forward a tad,moves the hood latch forward on the left side, putting spacers between the trans and frame messes up the rear fender mount. just hair pulling.I keyed 61.5 inch belt,I know it is 61.35 but I thought a .5 would be more realistic to find on google,nothing. Edited August 11, 2021 by uglyblue66 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,090 #13 Posted August 11, 2021 That belt looks like a B-59 intended for an industrial application where belt tensions are constant. I would be trying a trusted Gates or Napa green replacement for the application. Garry Share this post Link to post Share on other sites
uglyblue66 113 #14 Posted August 20, 2021 Ok,I need to know if there are new "terminals" available to go in the black connector that hooks to the key switch. I guess I could dig up a old wiring harness and try to salvage some but would rather just get pigtails or whatever to repair this connector. But the key switch acted funny and I had trouble getting the connector loose and when I did,the terminals on the switch were rusty.I cleaned them with the blasting cabinet but the actual terminals that connect to them in the harness are broke and don't apply any tension to hold them or connect them. I spoke to the fellow at The Electric Tractor Store, https://www.freerangeelectric.com/. He did show to have a "brain" in stock but when I inquired he removed the link. BUT he said he repairs them in house and that I could send mine in to have it repaired. so if I can't figure it out being something else, I might do that. still don't have a solution on the belt issue. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,090 #15 Posted August 20, 2021 NOTE I am now thinking what is below is completely wrong. There are conflicting parts lists on the model. The ignition switch for this model is very common. Click on the picture in the link to see the connector. 1 Share this post Link to post Share on other sites
uglyblue66 113 #16 Posted August 20, 2021 (edited) That is how my switch is reading,continuity is on 3 terminals with the switch turned on. The s terminal has no connector in the wiring harness for it. I am going to dig around today and see if I can find a old wiring harness to get the terminals out it.Thanks for the link sir! HUM< with that part number,I found this on ebay! May be a easier solution! https://www.ebay.com/itm/112475723300?epid=932678247&hash=item1a30135624:g:b7wAAOSwYXVYzUCw Edit again,just bought,I want this thing to work! Edited August 20, 2021 by uglyblue66 Share this post Link to post Share on other sites
uglyblue66 113 #17 Posted August 28, 2021 Well, I put the pig tail on this morning and the MOTOR starts and works correctly! ME gots it ! I am tickled. Now to move along to the metal components that are missing,and deal with the belt issue and blah blah blah.BUT at least I know the machine will WORK! 3 Share this post Link to post Share on other sites
8ntruck 7,069 #18 Posted August 31, 2021 You might try a slightly larger diameter (by 1/2" maybe?) idler pulley to help with your belt delema. The larger idler pulley would keep the spring compressed and would take up a little belt length as the belt blends around the larger diameter. 1 Share this post Link to post Share on other sites
uglyblue66 113 #19 Posted September 1, 2021 (edited) I have been working on battery boxes,I guess that is what you would call them,or battery racks. Thanks to the parts list pictures,and some web pictures and rust marks on the frame and some measurements of battery's I am coming along ok on them. I hope the wheel horse God's don't smite me for using angle iron and flat plate on most of it to make them as bending 10 gauge without a brake is about impossible. I will post a pic when I get them red and bolted on. All of the battery support brackets,shelfs and stuff is or was GONE when i got the machine.. Even a part that held the rear fenders up from the transmission was gone to.That was the first piece I had to make for the back end before I could make the rest of the box. I have the back 1 about done except for paint, the top shelf for the front is done except for drilling holes and paint.The bottom battery shelf or rack,I will be welding it up tomorrow. The front and back of it have 3/8ths slots almost the width of the rack so it can be slid out on rollers bolted to the frame. I will measure and try to cut those slots with the plasma cutter. I am not "restoring " this machine,at least not any time soon,I just want it fully functional. I am concerned if i make it to "pretty" people will think I fabricated it instead of it being a actual wheel horse model. Edited September 1, 2021 by uglyblue66 Share this post Link to post Share on other sites
8ntruck 7,069 #20 Posted September 1, 2021 (edited) Those electric Wheel Horses typically have rust from the corrosive nature of the batteries. I wonder if the pickup truck box coating products would help with corrosion resistance? Edited September 1, 2021 by 8ntruck 1 Share this post Link to post Share on other sites
uglyblue66 113 #21 Posted September 1, 2021 I don't know, I will just be painting the parts I am making as I will be using AGM batterys that are sealed and don't typically leak and drool like standard batterys. Share this post Link to post Share on other sites
uglyblue66 113 #22 Posted September 1, 2021 (edited) Well here is some progress. I am sure there are some errors in the design as all I had to go by was some internet photos and the pictures from the parts manuals you folks have here on the site. I took some artistic libertys with a couple things and that slot was a pain to cut for the bolts to be in on the bottom battery tray.There are rollers attached to the frame and the tray has a bolt on each side to remove and then slide the tray 1 side or the other to service the battery's. The rod on the front of the top tray has 2 cotter pins in it instead of a threaded nut on 1 end. Simpler. The back tray, the lip facing the rear of the tractor on the diagram showed to have 1 bolt holding the back on it,I used 2. The vertical piece on the right side of the trans-axle,I had to make that to.it was missing.I just mirrored the other side. The front bottom tray will get paint tomorrow.We are getting the last rain from the hurrycaine at the moment. Edited September 1, 2021 by uglyblue66 1 2 Share this post Link to post Share on other sites
uglyblue66 113 #23 Posted September 6, 2021 (edited) Well I drove it today.Got 6 batterys in it and drove it about 15 minutes.That annoying alarm buzzer let me know I was over drawing going up a hill in 3rd high so I had to back it down 1 to make the "Brain" box happy. The charger,well I plug it in and the green light blinks. So apparently the batterys are purty well charged up. I will get a pic or 2 up.IT is not put back together.I sat on top of a piece of rubber ,no seat,no fenders, no hood,no belt guard,no ----- . I was riding the frame around. most of the noise was bouncing and squeaking. Pto relay is not kicking in.But I do have the negative loose from the plug and just hanging as there is a issue with the socket,sparked or something at some point in it's life and roasted the screw holding the wire in so I may have to replace the pto jack,which is literally a drying outlet same as GE used on the Elec Trak. EDIT< while trying to reinstall the rear fender and a seat,I realized there had to be something missing.So I looked at the handy dandy information here on the site and yep,according the picture there is a fender support bracket I will have to make. I knew something wasn't quite right. Edited September 7, 2021 by uglyblue66 Share this post Link to post Share on other sites
uglyblue66 113 #24 Posted September 7, 2021 Sadly the seat is to large. 1 Share this post Link to post Share on other sites
uglyblue66 113 #25 Posted September 7, 2021 (edited) BUT I will find something suitable that is not rusted out and torn up. I don't understand the battery situation to some degree. the battery's I am using must be taller than the originals. Different type I know for sure but I had no idea there was a difference in how tall they were. I had to put the old belt that was on the machine when I got it. It seems to pull and work fine but I had hoped to replace it with new. Edited September 7, 2021 by uglyblue66 2 Share this post Link to post Share on other sites
