David414
312-h lower belt guard
David414
1991, 312-h, model 5112KE01
Drive belt calls for part #108501 which is a 5/8 x 81.5" v belt. I cant find this belt but can purchase a 5/8 x 81" or 82" belt.
Does the 1/2" difference in belt size create problems? Which is a better fit, the 81" or 82" if I cant find the 81.5" belt?
Thanks!
David414
 The parts diagram, section 8  (sheet metal and covers) shows a lower belt guard part #106352 that bolts to the underside of the RH foot rest. Does this guard apply to the 312-h or just the 8 speed transmissions?
Parts diagram section 14 ( Drive belt, pulleys and pto clutch) lists belt guards for the 8 speed transmissions, and the 416 , but nothing for the 312-h? Is this correct?
Does the 312-h have a lower belt guard and what is the part number?
Thanks
The
gwest_ca
This original parts list may help
Gates lists a 6982 82" belt replacement for 108501 (Napa 5L820W)
Garry
