dsholler
Idler pulley for attach-a-matic from 1986 414-8
dsholler
I am sure this answer is in here someplace, but all my best searching has not been able to find the right manual or parts diagram. I need to replace the idler pulley in the attachamatic, as it is squealing something awful. The mower belts probably could use an upgrade as well (Its the 48 inch side discharge deck, with the two belts)
Does anyone know where to source this pulley? It is the flat one, not the v one.
Dan
oliver2-44
When you disassemble your mule drive mark the 2 spacers that go through between the pulleys. They are 2 slightly different lengths and need to be reinstalled in the correct places.
gwest_ca
dsholler
Thanks for the tip about the spacers.
