kpinnc
Upgraded the tractor lift
kpinnc
I've had this thing for years. I built it back in 2012, and it has had little upgrades ever since.
Original build thread
What isn't in the pics are the ramps used to drive on or off the lift. Just regular ATV ramps.
Trouble is, when it has a tractor on it, the thing is hard to manuver around. The steering worked fine, but it won't turn sharp at all since it is so long. The other issue is when the tires sit sometimes for months, one or all leak down. Guessing the sidewalls just don't get exercised enough. Even factory mounted tires would leak down.
The pics here are the 'before'.
Edited by kpinnc
  • Like 6
kpinnc
So I changed the wheels out to flat free, and put casters on the front. Now I just need to redesign the handle. If it is fixed so it only moves up and down, it will work better with the casters.
At least now it can be backed up when pulling it with a tractor. The handle redesign will make it even better.
Edited by kpinnc
  • Like 7
kpinnc
And the new rear wheels. Much better!
  • Like 8
ebinmaine
Excellent work 👍
SylvanLakeWH
:text-yeahthat:
Very nice!
Herder
Vary nice, but I have to ask about the tires.  Who makes them?  I like them!!
kpinnc
I have to be honest, I don't know who actually made them- but they are called Z-134 and are 25x10-12. Pretty heavy duty so far as thickness and tread depth. I got them because they looked pretty cool and were cheap. Amazon had them for a while, but I don't see them now.
Edited by kpinnc
kpinnc
Changed the handle today so it only swings up and down. Makes moving much easier with the casters, because this sucker is heavy with a tractor on it!
Edited by kpinnc
kpinnc
Never really took a pic of loading/ unloading a tractor before, but this is what it looks like. The big tires on this tractor make it tricky, but you can see how it works. Normally the ramps are on blocks up front.
Get the weight on the wheels, and pull the pins to release the clamps. Drive on and off.
Compared to full up:
Edited by kpinnc
  • Heart 1
kpinnc
While it had nothing on it, here is full down.
  • Like 5
