peter lena 9,093 #1 Posted August 3, 2021 amazed at all the fuel related issues and complaints , with a simple easy answer at every fuel top off, have you ever heard of STA-BIL FUEL STORAGE ADDITIVE ? https://www.walmart.com/ip/STA-BIL-Fuel-Stabilizer-16oz-22207/26956845?wmlspartner=wlpa&selectedSellerId=101070860&&adid=22222222227000000000&wl0=&wl1=g&wl2=c&wl3=42423897272&wl4=pla-51320962143&wl5=9003307&wl6=&wl7=&wl8=&wl9=pla&wl10=408277686&wl11=online&wl12=26956845&veh=sem&gclid=CjwKCAjw0qOIBhBhEiwAyvVcf9yHBeihXrWOlrgZgHjYNMbBa4WRqSYaHYTTZqF5bLKqNE_FPbHrvBoC2zAQAvD_BwE&gclsrc=aw.ds get mine at wally world , and add it to every drop of fuel I use , typically the upper squeeze neck full to a top off. do not have any related debris or build up in my fuel related engines, my generator , sits for months , with instant starts , my horses , run regularly with STA- BIL treated fuel , no debris in carbs , pretty easy , every time I add gas I add STA- BIL , VERY SORRY IF I OFFENDED ANYONE , with this suggestion , why not try it ? pete 2 2 Share this post Link to post Share on other sites
Achto 28,806 #2 Posted August 3, 2021 I use SeaFoam in non-ethanol gas the same way that you use Stabil, with the same results. 3 Share this post Link to post Share on other sites
peter lena 9,093 #3 Posted August 3, 2021 @Achto, glad to hear that , what else works for you ? pete 1 Share this post Link to post Share on other sites
Ed Kennell 40,541 #4 Posted August 3, 2021 (edited) I treat my E-10 fuel with Sea Foam for normal use. I use a Sta-Bil Marine, 2 cycle oil, E-10 cocktail for long term storage of all engines. 4 stroke, 2 stroke, and marine outboards. No fuel problems ever. Edited August 3, 2021 by Ed Kennell 2 Share this post Link to post Share on other sites
varosd 1,185 #5 Posted August 3, 2021 Ethanol free gas in anything with a carb. www.pure-gas.org 2 Share this post Link to post Share on other sites
roadapples 6,983 #6 Posted August 3, 2021 I've been using Star tron for years. 5 Share this post Link to post Share on other sites
Zeek 2,286 #7 Posted August 3, 2021 (edited) I used to use Stabil until I researched a little more. I 'm no longer an additive fan. You are going to get a HUGE debate on this if you search the forum. Although this guy is a goof and I don't wear fake teeth unless to embarass my daughter when she visits, this video and others pretty much show that simply keeping oxygen out of your fuel keeps it pretty well. The test he did was pretty informative. I AM religious about using non-ethanol gas, because I have had experience with that gumming up fuel screens on small carbs WITH Stabil. . Other than that I circulate ten (10) 5 gallon fuel containers in my equipment/motorcycles. I have never had fuel less than 8 months old "go bad" (smell like varnish) ever. Why not save the money and try it and see for yourself? I should add that I drain the carbs and tanks of tractors or things like chainsaws if I don't know his long it will be until used again or I know it will be longer than 8 months. Edited August 3, 2021 by Zeek 2 Share this post Link to post Share on other sites
lynnmor 7,577 #8 Posted August 3, 2021 5 hours ago, Zeek said: Although this guy is a goof and I don't wear fake teeth unless to embarass my daughter when she visits, this video and others pretty much show that simply keeping oxygen out of your fuel keeps it pretty well. The test he did was pretty informative. This is his latest test video. My thought is that he should halt the test now and pull the carburetor bowls. I suspect that nearly all of them will have crud in them and those that did run may only be lucky enough to have the crud temporarily away from the jets. Share this post Link to post Share on other sites
Zeek 2,286 #9 Posted August 4, 2021 (edited) Here's where he talks about that. I'm still thinking unless you are totally neglecting stuff and letting it sit full of fuel for over a year, just drain it and refuel and don't let old gas in a piece of equipment. Seems pretty simple. . . Edited August 4, 2021 by Zeek Share this post Link to post Share on other sites
squonk 42,587 #10 Posted August 4, 2021 I buy the 94 octane VP fuel in gallons at TSC for the tractors that run once in awhile and in the plow mules for summer storage.. Yes it's expensive. But I've had fuel turn in 6 months. I suppose I got a bad batch. But it's easy insurance. Also add Seafoam on an occasional tank. I've had Sta-Bil leave tiny pink crystals in carb bowls. Share this post Link to post Share on other sites
roadapples 6,983 #11 Posted August 4, 2021 I'm not going to get in an argument here, just a simple question. What is in Seafoam that isn't in other additives. Why is one snake oil and the other not... Share this post Link to post Share on other sites
adsm08 2,702 #12 Posted August 4, 2021 5 hours ago, squonk said: I buy the 94 octane VP fuel in gallons at TSC for the tractors that run once in awhile and in the plow mules for summer storage.. Yes it's expensive. But I've had fuel turn in 6 months. I suppose I got a bad batch. But it's easy insurance. Also add Seafoam on an occasional tank. I've had Sta-Bil leave tiny pink crystals in carb bowls. Ford says to use Star-Tron in their plug-in hybrids and specifically calls out Sta-Bil as a fuel stabilizer to not use because it can separate out. The "fuel freshness strategy" which shuts down EV mode and forces you to run the rest of the tank out runs an 18 month schedule, so they are looking at basically storing a tank of fuel for a year and a half. 1 Share this post Link to post Share on other sites
oldredrider 2,553 #13 Posted August 4, 2021 8 minutes ago, roadapples said: What is in Seafoam that isn't in other additives. Proprietary ingredients. Much like the "11 secret herbs and spices." 1 1 Share this post Link to post Share on other sites
lynnmor 7,577 #14 Posted August 4, 2021 6 hours ago, oldredrider said: Proprietary ingredients. Much like the "11 secret herbs and spices." Some have made their own using their MSDS, the ingredients are as follows: 40-60% Pail Oil: Diesel Fuel, Automatic transmission fluid, or a light motor oil. 25-35% Napatha 10-20% IPA AKA: Isopropyl Alcohol If you can find a snake, add some of that. 1 Share this post Link to post Share on other sites
peter lena 9,093 #15 Posted August 4, 2021 should have said that I only buy ethanol fuel , nothing exotic , and sta-bil has not let me down for any fuel build ups , realize that others are finding it necessary to get a ethanol free fuel . for trouble free running , have not had that problem. just sta-bil has worked for me . no build up or debris any ware. run my stuff regularly, and rotate tractors to share the yard work. that is just works for me , pete 1 Share this post Link to post Share on other sites
Lee1977 7,044 #16 Posted August 5, 2021 I run non E fuel can't remember the last time I had a WH carburetor apart. When I get one not running right I give it a dose of Star-Tron and the problem goes away. You can call it Snake Oil or what ever you like but it works for me. I like Star-Tron but I do have Sea Foam and Stabil. I left E gas in my vacuum for over a year and It wouldn't start, gave the carb a dose of It think I had Stabil let it set 30 minuets and it fired up. Smokes like crazy for a few minuets didn't have to take that one apart.. I also try that method on chain saws, weed eaters, and hedge trimmers but some times they have to come apart because of busted driframs. 1 Share this post Link to post Share on other sites
Tuneup 1,433 #17 Posted August 5, 2021 VP fuels? Wow! I didn't even spoil the Suzuki, at Barber, on anything but 89 pump. I miss that machine (turn 5 did its damage). I wonder if the 516 would run better on VP. When we're done with this thread, how about a conversation on dino vs. synth, or Onan vs. Kohler, NGK vs Autolite? What a grand conversation could be had. Share this post Link to post Share on other sites
lynnmor 7,577 #18 Posted August 9, 2021 Here is the conclusion of the snake oil testing. If you don't want to waste your time watching, it is all just snake oil. Share this post Link to post Share on other sites
pacer 3,176 #19 Posted August 9, 2021 Drifting off topic here, but I had an event couple years ago that blew my mind!! So I had a rear tine tiller that I hadnt used in some 8-9 years, just been sitting in the shed. One day my neighbor asked if I still had it and could he borrow it .... Okay, I go get it air the tires (they actually held air) get it to the shop and I tell him we gotta drain the old fuel .... hes in a big rush -- and HARD headed and sez, naw I dont wanna mess with that, lets try it....... well OK go ahead -- cranked on the second pull, I bout fainted. Share this post Link to post Share on other sites
Bill D 2,097 #20 Posted August 9, 2021 Working on a Ariens GT 20 for a friend. The tanks is full of old fuel that still smells good. I think it might be MTBE gas, not ethanol fuel. Didn't try to run it on that gas. Share this post Link to post Share on other sites
