Gregor 4,846 #1 Posted August 3, 2021 I want to put a snow plow on one of my tractors. I don't know which tractor yet. I was wondering, what is the best set up for pushing snow on a concrete driveway? Bar tires? with chains? Turff tires? with chains? ATV tires? with chains? Or is there something else? Thanks Greg Share this post Link to post Share on other sites
Pullstart 62,807 #2 Posted August 3, 2021 Based on discussions of the past, a well weighted turf tire in winter time will always outperform a bar/Ag tread. Add chains (and even more weight) and fluid fill ‘em, you’ll be in good shape for pushin! 3 1 Share this post Link to post Share on other sites
rjg854 11,352 #3 Posted August 3, 2021 Keep in mind that chains may mark up the concrete, they do have rubber chains for concrete and asphalt. Share this post Link to post Share on other sites
SylvanLakeWH 25,500 #4 Posted August 3, 2021 I run turfs with no added weights or chains. Three flat drives with typical Michigan slop er… snow… works fine for me and no marks… 1 Share this post Link to post Share on other sites
Gregor 4,846 #5 Posted August 3, 2021 I have a set of weights, and a tractor with turf tires. I will try that, and add chains only if necessary. Thanks All 1 Share this post Link to post Share on other sites
Achto 27,511 #6 Posted August 3, 2021 I have heard rave reviews on the Carlisle Versa Turf tires. Some even claiming that they no longer need chains. They are supposed to kind to your lawn as well. https://www.millertire.com/23x8-50r12-carlisle-versa-turf-compact-radial-tractor-tire-6-ply/ Share this post Link to post Share on other sites
Gregor 4,846 #7 Posted August 3, 2021 I'm kind-a liking these https://www.millertire.com/26x12-00-12-carlisle-versa-turf-compact-radial-tractor-tire-4-ply/ Share this post Link to post Share on other sites
8ntruck 6,991 #8 Posted August 3, 2021 Interesting tire..... Share this post Link to post Share on other sites
WheelHorse520H 708 #9 Posted August 9, 2021 On 8/3/2021 at 6:30 AM, Gregor said: Bar tires? with chains? Turff tires? with chains? ATV tires? with chains? Previously I have had regular turf tires with metal chains that worked good. I have a driveway with pavement and gravel spots. Worked pretty good on both. No weights either. Share this post Link to post Share on other sites
