TJ5208 1,824 #1 Posted July 18, 2021 (edited) What tire pressure should I run for a worker tractor like pulling things plowing snow plowing pushing dirt and gravel and snow and ploughing dirt rear and front Edited July 18, 2021 by TJ salyers Share this post Link to post Share on other sites
8ntruck 7,256 #2 Posted July 18, 2021 I run mine somewhere between 10 and 14 psi. Both the front and rear. If you run too much pressure, the center of the tread will bludge, forcing the edges of the tread away from the ground. Too little, and the center of the tread bows up and away from the ground, leaving the edges of the tread doing most of the work. 2 Share this post Link to post Share on other sites
ebinmaine 69,710 #3 Posted July 19, 2021 We run 8 to 10 rear. 12 to 15 front. 1 Share this post Link to post Share on other sites
Lee1977 6,917 #4 Posted July 19, 2021 15 hours ago, ebinmaine said: We run 8 to 10 rear. 12 to 15 front. Eric runs tubes in his tires and can get by with less pressure then a tubeless tire. As said above you want to keep the tread level on the ground. You might not be able to do that with a tubeless 2 ply and keep the tire on the rim. I took a set of 950 2 ply off my 520 when I got it when the tire level out there wasn't pressure left to keep the tire on. Did I say I hate 2 ply tires. Share this post Link to post Share on other sites
Jeff-C175 7,203 #5 Posted July 19, 2021 28 minutes ago, Lee1977 said: Eric runs tubes in his tires and can get by with less pressure then a tubeless tire. As said above you want to keep the tread level on the ground. You might not be able to do that with a tubeless 2 ply and keep the tire on the rim. I took a set of 950 2 ply off my 520 when I got it when the tire level out there wasn't pressure left to keep the tire on. Did I say I hate 2 ply tires. My C-175 book says 12 PSI front and rear for the 2 ply tubeless Turf Savers. I've got 4 ply Turf Masters on there as of this season and running 12 PSI tubeless has not been a problem, but neither was it a problem with the 2 ply either. Share this post Link to post Share on other sites
John2189 476 #6 Posted July 19, 2021 I just put enough in to take the bulge out of the side wall Share this post Link to post Share on other sites
