Talyn walsh 2 #1 Posted July 14, 2021 Okay so I had a c125 with the k301 and it was rough so I rebuilt the engine and restored most of the tractor I re did all of the wiring and I went off the wheel horse owners manual for the wiring diagram everything looks like it should I have replaced all of the accessories all of the ignition system is brand new literally everything I set the breaker points I’ve checked and make sure everything is perfect probably 50 times and still I have no spark the only possible way I get spark is when I put a pair of jumper cables on a different tractor and hook them up to my ignition coil on the c125 that is the only way I see spark actually happening please someone out there help me I’ve been trying to figure it out for almost a year now Share this post Link to post Share on other sites
Maxwell-8 4,366 #2 Posted July 14, 2021 (edited) Maybe a picture could help. Edited July 14, 2021 by Maxwell-8 Share this post Link to post Share on other sites
Gregor 4,847 #3 Posted July 14, 2021 (edited) There are so many possibilities, it's hard to know where to begin. What if any safety switches have you hooked up on the tractor? Seat switch? Brake pedal switch? PTO switch? Did you replace the ignition switch? There are 2 types of switches. One is for battery ignition, the other for magneto ignition. They are NOT interchangeable. Edited July 14, 2021 by Gregor 5 Share this post Link to post Share on other sites
Achto 28,159 #4 Posted July 14, 2021 (edited) Are you getting power to the "+" side of the coil when the ignition switch is on? Edited July 14, 2021 by Achto 1 Share this post Link to post Share on other sites
OutdoorEnvy 1,693 #5 Posted July 14, 2021 Yeah lots of options here but start simple and go from there. If you painted anything or there is lots of rust I would check all ground locations and remove paint and rust so you have good metal to metal contact for all grounds, especially the negative battery cable ground spot for the tractor. Use dielectric grease too on the grounds if you have it. It helps. A multimeter will help a lot as you determine the power path and where the loss is occurring. Starter switch and solenoid are the first places to check once you have established all grounds are good. Then on to safety switches if those check out fine... good luck with it. Stay the course and it will get worked out... Share this post Link to post Share on other sites
Pullstart 63,497 #6 Posted July 14, 2021 It could be as simple as using the wrong ignition switch too. Pictures of what you have going on, having a volt meter at your ready and using a known wiring diagram and understanding where the power travels will help us all tremendously! Share this post Link to post Share on other sites
953 nut 56,694 #7 Posted July 14, 2021 5 hours ago, Talyn walsh said: I put a pair of jumper cables on a different tractor and hook them up to my ignition coil on the c125 that is the only way I see spark actually happening If you run a jumper from the battery on the C-125 to the coil + do you get a spark? Will the engine turn over from the key but there is no spark? With the key in the on position do you have 12 volts to the coil +? 1 Share this post Link to post Share on other sites
squonk 41,886 #8 Posted July 14, 2021 Is this a shaker plate mounted engine? If so check the separate ground cable for the plate and connections 1 Share this post Link to post Share on other sites
Ed Kennell 39,715 #9 Posted July 14, 2021 6 hours ago, Talyn walsh said: only possible way I get spark is when I put a pair of jumper cables on a different tractor and hook them up to my ignition coil on the c125 that is the only way I see spark actually happening please Does the engine run OK when you add a jumper from the 125s + battery to the + coil post? If it does, it is clear there is a break in the ignition circuit. Use your VOM to backtrack the circuit from the coil to find the point where the 12v. is missing. Could be the ignition switch, seat, PTO, pedal safety switches, or a broken wire. 1 Share this post Link to post Share on other sites
Talyn walsh 2 #10 Posted July 14, 2021 4 hours ago, Achto said: Are you getting power to the "+" side of the coil when the ignition switch is on? I’m not sure I’ll have to check Share this post Link to post Share on other sites
Talyn walsh 2 #11 Posted July 14, 2021 2 hours ago, 953 nut said: If you run a jumper from the battery on the C-125 to the coil + do you get a spark? Will the engine turn over from the key but there is no spark? With the key in the on position do you have 12 volts to the coil +? The engine turns when I turn the key I’m not sure if I’m getting 12v to the + on the coil I really don’t think I am if I’m getting getting 12v whats should I do Share this post Link to post Share on other sites
Talyn walsh 2 #12 Posted July 14, 2021 6 hours ago, Gregor said: There are so many possibilities, it's hard to know where to begin. What if any safety switches have you hooked up on the tractor? Seat switch? Brake pedal switch? PTO switch? Did you replace the ignition switch? There are 2 types of switches. One is for battery ignition, the other for magneto ignition. They are NOT interchangeable. I replaced the ignition switch with the same one from factory just a 5 prong 2 position ignition switch Share this post Link to post Share on other sites
Talyn walsh 2 #13 Posted July 14, 2021 4 hours ago, Achto said: Are you getting power to the "+" side of the coil when the ignition switch is on? I don’t think so I’m gonna have to check that out if I’m not getting the 12v what do I do Share this post Link to post Share on other sites
Talyn walsh 2 #14 Posted July 14, 2021 2 hours ago, squonk said: Is this a shaker plate mounted engine? If so check the separate ground cable for the plate and connections The grounds wires that are on the plate that mount the engine to the frame? Share this post Link to post Share on other sites
Talyn walsh 2 #15 Posted July 14, 2021 3 hours ago, pullstart said: It could be as simple as using the wrong ignition switch too. Pictures of what you have going on, having a volt meter at your ready and using a known wiring diagram and understanding where the power travels will help us all tremendously! I don’t have any pictures right now but I have a 5 prong ignition switch with 2 positions Share this post Link to post Share on other sites
Talyn walsh 2 #16 Posted July 14, 2021 6 hours ago, Gregor said: There are so many possibilities, it's hard to know where to begin. What if any safety switches have you hooked up on the tractor? Seat switch? Brake pedal switch? PTO switch? Did you replace the ignition switch? There are 2 types of switches. One is for battery ignition, the other for magneto ignition. They are NOT interchangeable. When I got the tractor it was bad it was basically being eaten by nature for probably 12 years and when I pulled it all apart and re did the wiring I took the only safety switch out which was the PTO safety switch i by passed it and got rid of it because I was trying to make the wiring as simple as possible and I didn’t really care to have the PTO switch Share this post Link to post Share on other sites
Talyn walsh 2 #17 Posted July 14, 2021 3 hours ago, OutdoorEnvy said: Yeah lots of options here but start simple and go from there. If you painted anything or there is lots of rust I would check all ground locations and remove paint and rust so you have good metal to metal contact for all grounds, especially the negative battery cable ground spot for the tractor. Use dielectric grease too on the grounds if you have it. It helps. A multimeter will help a lot as you determine the power path and where the loss is occurring. Starter switch and solenoid are the first places to check once you have established all grounds are good. Then on to safety switches if those check out fine... good luck with it. Stay the course and it will get worked out... I checked all my grounds except the negative battery wire I’m gonna go back today and make sure everything and I mean literally everything is where it is supposed to go and make sure everything has a clean connection Share this post Link to post Share on other sites
Gregor 4,847 #18 Posted July 14, 2021 While you are there, as mentioned earlier, run a jumper wire directly from battery + to + on coil. 1 Share this post Link to post Share on other sites
Talyn walsh 2 #19 Posted July 14, 2021 6 minutes ago, Gregor said: While you are there, as mentioned earlier, run a jumper wire directly from battery + to + on coil. What I was doing is I have a 520 and I drove the 520 up the the 125 and put the positive and negative onto the 520 battery and then put the other side of the jumper cables onto the positive and negative on the ignition coil on the 125 but I haven’t tried running a jumper from the positive on the 125 battery to the + on the ignition coil i should try that Share this post Link to post Share on other sites
Gregor 4,847 #20 Posted July 14, 2021 1 minute ago, Talyn walsh said: What I was doing is I have a 520 and I drove the 520 up the the 125 and put the positive and negative onto the 520 battery and then put the other side of the jumper cables onto the positive and negative on the ignition coil on the 125 but I haven’t tried running a jumper from the positive on the 125 battery to the + on the ignition coil i should try that Yes I am guessing, since you can crank your motor over with the key, your grounds should be ok. But there are always exceptipons Share this post Link to post Share on other sites
Achto 28,159 #21 Posted July 14, 2021 1 minute ago, Talyn walsh said: put the positive and negative onto the 520 battery and then put the other side of the jumper cables onto the positive and negative on the ignition coil on the 125 This should not be done this way. Don't hook a negative lead to the negative on the coil. Only a power wire to the positive side of the coil. Your points need to create the ground for the negative side of the coil. 3 Share this post Link to post Share on other sites
Talyn walsh 2 #22 Posted July 14, 2021 4 minutes ago, Gregor said: Yes I am guessing, since you can crank your motor over with the key, your grounds should be ok. But there are always exceptipons So should I try to run jumper from my battery to the + and - on my ignition coil and see if that works if that does work and I get spark what should I do from there Share this post Link to post Share on other sites
Gregor 4,847 #23 Posted July 14, 2021 Only 1 wire Battery + to coil + Thats all 2 1 Share this post Link to post Share on other sites
Gregor 4,847 #24 Posted July 14, 2021 Here are 2 ignition switches. The top one is 5 pole 3 position (stop, run, start) battery ignition switch from Amazon. The bottom one is a 5 pole, 3 position, (stop, run, start) magneto ingition switch from Oreily Auto parts. My point is. Both switches are 5 pole, 3 position, identical looking switches. They are NOT the same. Do you happen to know the part number of the new switch you installed? 2 Share this post Link to post Share on other sites
Achto 28,159 #25 Posted July 14, 2021 5 minutes ago, Talyn walsh said: So should I try to run jumper from my battery to the + and - on my ignition coil and see if that works if that does work and I get spark what should I do from there As @Gregor said only a wire from the "+" side of the battery to the "+" side of the coil. NOTE - Do not leave this jump wire on for a long period of time with out the engine cranking, you will at best burn your points, at worst over heat and wreck your coil. Best practice would be to turn your ignition switch "on" and see if you are getting power on the "+" side of the coil. If you are not, figure out why and fix the issue. 1 Share this post Link to post Share on other sites
