45to70 61 #1 Posted July 13, 2021 Hi. Am an old guy that just got a 753 at auction. Know next to nothing about it and hope to get a lot of help here. First problem is trans is stuck in gear, the gear shift lever moves but the wheels are locked. Can just rock it back and forth a few inches. Any help greatly appreciated. Thank in advance Share this post Link to post Share on other sites
953 nut 56,741 #2 Posted July 14, 2021 Could be a simple fix, read over this thread. 2 Share this post Link to post Share on other sites
WHX?? 49,919 #3 Posted July 14, 2021 (edited) A 753 is a favorite model here. Well I guess any is a fav here! You need to pull the shifer and ...well looks like Richard is a faster typer... lol. The dog point set screw is a bugger to get at but a long 1/8 Allen wrench helps. We can get you some manuals if you need. Edited July 14, 2021 by WHX24 2 Share this post Link to post Share on other sites
Pullstart 63,529 #4 Posted July 14, 2021 I don’t discriminate, I like all round hoods the same! 1 Share this post Link to post Share on other sites
Achto 28,189 #5 Posted July 14, 2021 31 minutes ago, WHX24 said: The dog point set screw is a bugger to get at but a long 1/8 Allen wrench helps. A previous owner cut slits in my 701 so they could bend the sheet metal back in order access the dog point screw. I don't recommend that this practice be carried out. 3 Share this post Link to post Share on other sites
rjg854 11,709 #6 Posted July 14, 2021 I'll just say and hope that your problem is an easy fix. Share this post Link to post Share on other sites
WHX?? 49,919 #7 Posted July 14, 2021 It might be just as simple as two gears at once. Pull the shifter and look for the H pattern. Use a longer screwdriver to move the forks to try and get the H. 1 Share this post Link to post Share on other sites
45to70 61 #8 Posted July 14, 2021 Thanks for the info.............don't know if I will be able to get at it today as am up to my rear end in alligators right now. Its still sitting on the back of my deuce & 1/2, am really looking forward to getting her in the garage and playing with her. . Bought it because have always liked the looks of these old horse's. Yeah, it pretty crusty, but then so am I. Thanks again! 2 2 2 Share this post Link to post Share on other sites
45to70 61 #9 Posted July 14, 2021 Am going to flush out the trans while am at it. How much gear oil does it take? 1 Share this post Link to post Share on other sites
Pullstart 63,529 #10 Posted July 14, 2021 54 minutes ago, 45to70 said: Am going to flush out the trans while am at it. How much gear oil does it take? 1-1/2 to 2 qts in the transmission. You can fill it right through the shifter hole if you get good at pulling it out 1 Share this post Link to post Share on other sites
WHX?? 49,919 #11 Posted July 14, 2021 Drain the oil and see what it looks like if it's miky in color water has gotten into it so not a bad idea to flush it with diesel or kerosene. Refill through the shifter lever hole if possible. About a Qt and 1/2 or up to the plug hole on the back left side. 2 1 Share this post Link to post Share on other sites
45to70 61 #12 Posted July 14, 2021 Got It....................Thanks Share this post Link to post Share on other sites
rjg854 11,709 #13 Posted July 14, 2021 There is a hump in the center of the transmission, while draining it, raise the front of the tractor as high as you can to get all the fluid out, especially the diesel fuel. 2 Share this post Link to post Share on other sites
WHX?? 49,919 #14 Posted July 14, 2021 It helps flushing if you can get her running and drive it around abit. Did anyone mention we like ? Share this post Link to post Share on other sites
45to70 61 #15 Posted July 14, 2021 (edited) Well that did the trick.......she rolls now............trans has diesel in it..........am going to need some seals as its coming out of the wheel hubs. At least now can get it off the truck. Looked like mud inside the gear box. Have not tried to get it running yet. thanks again and know I'll be back with lots more questions. Edited July 14, 2021 by 45to70 2 1 Share this post Link to post Share on other sites
WHX?? 49,919 #16 Posted July 14, 2021 (edited) 9 minutes ago, 45to70 said: know I'll be back with lots more questions. Glad we could help.... Ask away! Some times it will leak out in back of the hubs since it's much thinner than 80/90. One thing you will want to do is jack up the rear and check the outboard wheel bearings. Move the wheel up and down and back and forth. there should be a little movement but no more than say 1/16". The seals can be replaced from the outside if no movement. Also check the tightness of the hub set screw and the condition of the keyway while you are back there. If the shifter boot is shot replace it ..... that's how water got in there. Edited July 14, 2021 by WHX24 2 Share this post Link to post Share on other sites
stevasaurus 22,968 #17 Posted July 14, 2021 The shift rails in these early horses can have a suction problem when shifting fast (usually from 2nd to reverse or vise versa). In other words, when shifting fast from reverse to 2nd, the shifter leaves one shift rail fork and grabs the other. If there is enough suction, the vacated shift rail fork can get sucked back and then you are in 2 gears at the same time. The only quick fix is to do what you did. To help to not have this happen, never shift without coming to a complete stop. Do not shift fast, take your time and use a deliberate "H" pattern. BTW...Welcome to Red Square. 2 1 Share this post Link to post Share on other sites
953 nut 56,741 #18 Posted July 14, 2021 8 hours ago, 45to70 said: going to need some seals Lowell can fix you up. https://wheelhorsepartsandmore.com/product-category/manual-transmissions/ 2 Share this post Link to post Share on other sites
45to70 61 #19 Posted July 15, 2021 Rodger, Willco..got it off the deuce, put a new battery in it and gas of course, checked the oil,...............and she fired up with a short blast of starting fluid and the dies, but then noticed its got no throttle cable and the air filter is filthy............will hit it again tomorrow...........it surprised the heqq out of me that she ran. many thanks Al 2 Share this post Link to post Share on other sites
WHX?? 49,919 #20 Posted July 15, 2021 (edited) 1 hour ago, 45to70 said: ..it surprised the heqq out of me that she ran. Doesn't us AL .... many a Kohler that sat for years has started right up for us. My 753 sat for at least 6 years but fired right up with minor love. Buddy Dan's @Achto 753 prolly sat for 10 years or better and we had her singing inside of an hour... topless and all! May be I so bold as to suggest a quick carb cleaning, fuel lines & filter. Also go easy on the sniffing salts, they can wash cylinder walls of oil. Switch to choke cleaner if she is stubborn. Edited July 15, 2021 by WHX24 2 2 Share this post Link to post Share on other sites
45to70 61 #21 Posted July 15, 2021 37 minutes ago, WHX24 said: Doesn't us AL .... many a Kohler that sat for years has started right up for us. My 753 sat for at least 6 years but fired right up with minor love. May be I so bold as to suggest a quick carb cleaning, fuel lines & filter. Also go easy on the sniffing salts, they can wash cylinder walls of oil. Switch to choke cleaner if she is stubborn. Rodger! Share this post Link to post Share on other sites
