John2189 454 #26 Posted July 15, 2021 5 hours ago, squonk said: Everyone who would run this block, raise their hand! 5 hours ago, squonk said: Everyone who would run this block, raise their hand! I would break it off the rest of the way, if it is not close to where the rings would hit it and no other cracks in the cylinder wall. I would run it. john 1 Share this post Link to post Share on other sites
Gregor 4,846 #27 Posted July 15, 2021 Unfortunately, I don't believe you can see the piston on a Kohler, simply by removing the plug. On a small block, it is possible to check with a Tecky timing tool. It won't work on a big block, the tab will not reach the piston. I bought on of these from the Jungle Book. For $80, it shows a remarkably clear picture. It could show you what's in the pan, but of course to will not show you the extent of the damage. The endoscope is a very handy tool for a lot of things. I use mine on a regular basis. I can't wait to see pics of the inside of this engine. Share this post Link to post Share on other sites
Gregor 4,846 #28 Posted July 15, 2021 34 minutes ago, John2189 said: I would break it off the rest of the way, if it is not close to where the rings would hit it and no other cracks in the cylinder wall. I would run it. john I would remove the broken piece. If my machine shop told me there was no further damage, and no cracks, I would run it also. 1 Share this post Link to post Share on other sites
68 raider 12 3 #29 Posted July 18, 2021 I had an old timer in my town dissect the engine and it's confirmed the connecting rod snapped and the crank is a little busted up, the cylinder walk is surprisingly still in good condition no crack, scratch, or chips. Only problem is I'm having a hard time finding a replacement crankshaft for the Kohler k301s engine model. Anyone have one or know where to find one? Share this post Link to post Share on other sites
Gregor 4,846 #30 Posted July 18, 2021 17 minutes ago, 68 raider 12 said: Anyone have one or know where to find one? Personally, I would not invest any money in this engine, until the block is checked by a machine shop. Cracks are not always visible with out a magna flux test. If it turns out OK, you may be able to find a used short block on Facebook, but then again, you never know what you are buying. May ne be any better than what you have. Share this post Link to post Share on other sites
68 raider 12 3 #31 Posted July 18, 2021 The guy I had look at it has been working on engine his whole life, he told me it doesn't necessarily need a new crank but he wants to replace it while he's got the engine tore apart. I get he's not a machine shop specialist but I trust him. 1 Share this post Link to post Share on other sites
squonk 41,154 #32 Posted July 18, 2021 2 hours ago, 68 raider 12 said: I had an old timer in my town dissect the engine and it's confirmed the connecting rod snapped and the crank is a little busted up, the cylinder walk is surprisingly still in good condition no crack, scratch, or chips. Only problem is I'm having a hard time finding a replacement crankshaft for the Kohler k301s engine model. Anyone have one or know where to find one? I think I may have a 301 crank here.It will probably need turning Share this post Link to post Share on other sites
68 raider 12 3 #33 Posted July 18, 2021 4 hours ago, squonk said: I think I may have a 301 crank here.It will probably need turning What do you mean by turning?? Share this post Link to post Share on other sites
squonk 41,154 #34 Posted July 18, 2021 48 minutes ago, 68 raider 12 said: What do you mean by turning?? The crank came out of an engine with a broken rod. It had some aluminum melted on to the journal. I polished it but it may be out of round and need to be turned .010" undersize by a machine shop. Share this post Link to post Share on other sites
68 raider 12 3 #35 Posted July 23, 2021 On 7/18/2021 at 1:45 PM, squonk said: I think I may have a 301 crank here.It will probably need turning Do you have a picture of it?? Share this post Link to post Share on other sites
squonk 41,154 #36 Posted July 23, 2021 (edited) 5 hours ago, 68 raider 12 said: Do you have a picture of it?? Actually it belongs to a friend of mine who had the blown engine. i thought I had it here but he must have it. I'll get it tomorrow. Edited July 23, 2021 by squonk Share this post Link to post Share on other sites
squonk 41,154 #37 Posted July 24, 2021 (edited) Crankpin is out of round and depending on the accuracy of my old micrometer the crank cannot be turned down any more to use with an undersized rod. It would have to be built back up and re-machined or a rod machined for bearing inserts. You can read about this here:http://gardentractorpullingtips.com/engine.htm Edited July 24, 2021 by squonk 1 Share this post Link to post Share on other sites
WheelHorse520H 708 #38 Posted July 30, 2021 On 7/24/2021 at 12:48 PM, squonk said: It would have to be built back up and re-machined or a rod machined for bearing inserts. Just tuning in here for the education, how do you build it back up? Andrew Share this post Link to post Share on other sites
Jeff-C175 7,202 #39 Posted July 30, 2021 (edited) 26 minutes ago, WheelHorse520H said: Just tuning in here for the education, how do you build it back up? Andrew I had it done to an MG crankshaft a long time ago. The machinist builds the missing metal back up by welding and then re-machines it back to spec. I saw a YouTube video a while back where the guy used a 'spray welding' technique to repair a blower wheel journal but I don't know if that could be used for repairing a crank. Edited July 30, 2021 by Jeff-C175 Share this post Link to post Share on other sites
WheelHorse520H 708 #40 Posted July 30, 2021 10 hours ago, Jeff-C175 said: The machinist builds the missing metal back up by welding and then re-machines it back to spec. That’s what I was guessing, that’s the only way I know to build metal up that will withstand the forces of an engine. Share this post Link to post Share on other sites
richmondred01 2,237 #41 Posted July 31, 2021 A sleeve can be used to repair the chipped or cracked cylinder apron. The machine work and sleeve costs 150.00. Worth the cost for the k341. 1 Share this post Link to post Share on other sites
Gregor 4,846 #42 Posted August 1, 2021 On 7/13/2021 at 7:58 AM, squonk said: The crank will most likely be torn up where the rod used to be connected to it. That looks an awful lot like my MV-16. Share this post Link to post Share on other sites
richmondred01 2,237 #43 Posted August 1, 2021 95% of the engines I get with broken rods the crank looks like that. They generally clean up fine at .010 or .020. 40% of the engines I get that rods have broken have the chipped apron skirt. I’ve got several core blocks so I use them or put a sleeve in. 1 Share this post Link to post Share on other sites
squonk 41,154 #44 Posted August 1, 2021 5 hours ago, richmondred01 said: 95% of the engines I get with broken rods the crank looks like that. They generally clean up fine at .010 or .020. 40% of the engines I get that rods have broken have the chipped apron skirt. I’ve got several core blocks so I use them or put a sleeve in. Can you get .020" rods Mark? Share this post Link to post Share on other sites
richmondred01 2,237 #45 Posted August 1, 2021 I have .020 rods for 10hp through 16hp. I can’t get them any more for 8hp down. 1 Share this post Link to post Share on other sites
richmondred01 2,237 #46 Posted August 1, 2021 Here’s a sleeve. Of course it takes it back to standard size. 2 Share this post Link to post Share on other sites
Gregor 4,846 #47 Posted August 1, 2021 12 minutes ago, richmondred01 said: I have .020 rods for 10hp through 16hp. I can’t get them any more for 8hp down. Do you have anything at all for an MV-16S, spec # 56506 Share this post Link to post Share on other sites
richmondred01 2,237 #48 Posted August 1, 2021 6 minutes ago, Gregor said: Do you have anything at all for an MV-16S, spec # 56506 I don’t but I will PM you where you can get them. 1 Share this post Link to post Share on other sites
richmondred01 2,237 #49 Posted August 1, 2021 Before and after. I’m able the get most of them cleaned up. Share this post Link to post Share on other sites
Gregor 4,846 #50 Posted August 1, 2021 OK Mines not THAT bad. Share this post Link to post Share on other sites
