squonk
Makes no sense. What am I missing
squonk
Trying to get this engine to run from my engine stand thread. The points are opening at the beginning of the intake stroke. That's when the pushrod is moving out to open them (1st pic) The [parts engine I have moves the points open on the compression stroke like its supposed to. (2nd pic). Logic says it's 180 deg off BUT how can the lobes on the cam move? The cam drives the points as well as the valves. How can it be off like that ? Both pics are when the points begin to open. :confusion-confused: @richmondred01
v1.jpg.4199504813b41c047314a76d87ebbf2d.jpg  v-2.jpg.e045c1ca6e366560917bd45222bcd1bd.jpg
Edited by squonk
  • Confused 1
Ed Kennell
The points should open both times the piston is at top.   On the intake and the power stroke.
Pullstart
Different length points push rods?  Was it running before or a recent build?  Guessing here obviously...
squonk
Ed the cam turns half the speed of of the crankshaft so no that isn't the case.
squonk
Pushrods are the same length. I bought this engine as "Rebuilt and will run" At the show the kid says I can't get it to run. I 'll never buy an engine sight unseen again! :ranting:
ebinmaine
I'm no Small engine expert by a long shot but maybe the cam or crank is not the right one for that application?
Ed Kennell
Sorry Mike, I didn't realize that.   But, I guess that means the crank and points cam can be out of time with the valves.
Edited by Ed Kennell
squonk
I wondering the same thing. Who knows what this kid did to put it together.
squonk
Ed the points are driven off the same cam as the valves. So the cam would almost have to be twisted or possibly broken and rewelded wrong for the points lobe to out of whack with the valve lobes.
Edited by squonk
Pullstart
Well, it’s on the stand, right?  Lettuce know when you figure out what the cam looks like...
stevasaurus
are these K-181-S engines??
pacer
Setting the cam timing hasnt been mentioned --- with the unknown history of the engine, I would check to see if the cam is timed to the crank, usually a dot on cam tooth and a dot to match it on the crank.....
squonk
That was my thought, but the pushrod lobe should still be in time with the valve lobes. When the points open,the valves should be closed no matter where the cam is in relation to the crankshaft.
stevasaurus
Actually, Mike is right...it is all about the cam shaft.  Where the piston is has nothing to do with what is going on.  Look at this picture...the lobe for the points is to the right on the cam shaft.  The other two lobes work the valves.  The points should be opening when the valves are closed.  In the K-181, the cam shaft is one piece, hard to believe it is twisted or welded.  In the K-161 the cam is 2 piece...maybe we have a 7 hsp cam in there.  Any way, got to open it up Mike.  BTW, Mike, did you check the point gap?
20160207_133424.thumb.jpg.f64711e84fc096
credit to Pronzy for the picture.
squonk
I think my Brotha Dino is on to something.I got the impression that these kids had a bunch of engines laying around. Found 8HP written on the inside of the sheet metal. I wouldn't be surprised to find a 2 piece cam in there. Forgot all about that BS.
And yes sTEve, I have had the points on and off. It does this no matter where I set the gap.
stevasaurus
I knew it wouldn't make any difference Mike...just another piece of the kids doing things puzzle.  :occasion-xmas:
JCM
As Arte Johnson would say, Verrry Interesting, but stupid.
stevasaurus
Remember, there should be a brass washer on the cam shaft on the PTO side...easy to lose.  :orcs-cheers:
squonk
Looks like I'll be tearing down 2 to make 1
  • Sad 1
Snoopy11
True, but usually if it is off time, the cam will hit the rod...  dunno how much clearance is there, but this is usually the case if timing is off.
Might be that the cam is off timing, but it would be by quite a few teeth...
Tracking down this issue is going to take measurement, I think. Perhaps wrong length cam followers or pushrods...
If I am missing something here, feel free to ignore me... LOL
Don
stevasaurus
Not necessarily, if you just need another cam shaft, Shynon or Pronzy might have a spare.
squonk
IMG_20210712_160830216.jpg.12609e90931803d5834187f3ec486f30.jpg@stevasaurus does this look like a 2 piece cam? Good thing I took it apart. Hole in the rod cap is on the wrong side. :(
Edited by stevasaurus
I think so Mike...check thread below.
ebinmaine
Yeeeeesh
oldredrider
If that engine were mine, I'd take it completely down. Metal in the gears is a bad sign.
stevasaurus
Mike, here is the thread I was thinking of...scroll down and look at these pictures.
