dcairns560
Wheels lock up forward or reverse
dcairns560
My tractor is a 1977 D160 Automatic.  I used it yesterday moving dirt with the loader for several hours and everything functioned perfectly.  Today I backed out of the barn with no issues, then after moving forward several feet, the rear wheels locked up.  I was able to back up a few feet and again they locked up.  Once it locks up, if I try and push the motion control lever further, it sounds like hydraulic cavitation.  I made sure the push valve was closed and tight.  I opened the push valve to push it back to the garage, again after a few feet in either direction the wheels lock up.  If I jack up the rear end, the wheels spin just fine.  The fluid is clean and full.  Not sure if my issue is in the transaxle or the pump.
Any thoughts?
pfrederi
Most likely transaxle if it locks up with the tow valve open.  Maybe a broken Differential bolt that is getting jammed under the bull gear. Do not force it as you may crack the transaxle case...
Manual will help you click fuzy picture
stevasaurus
When you jack up the rear end and turn the wheels...one wheel should spin in the opposite direction.  All that tells you is that the gears inside your differential are OK.  It does not tell you anything else, because you are not turning the bull gear of the differential itself.  So, what Paul is saying is a very possible choice of what is going on.  I would take off the guard and drive belt and try turning (by hand) the input pulley counter=clockwise and see what happens then...with the tow valve open and with it closed.  If it locks up, you're already on your way to dropping the transaxle to open up.  :occasion-xmas:
   By turning the input pulley by hand, you will not brake anything and you will know that Paul figured it out.
pfrederi
  Steve  d160 wouldn't have an input pulley...  Also he coould try turning both wheels in eh same direction when jacked up and listen for any strange noise
  • Excellent 2
stevasaurus
No input pulley Paul???  Now I know why I try to stay out of "D" Threads...I know nothing about them.  :hide:
  • Haha 3
pfrederi
They are there own "special" breed.  :P
daveoman1966
My C-160 Auto had the same 'lock-up' symptoms.  Problem was one of the differential bolts worked loose, then got sheared off...locking the the internal gears when the tractor rolled fwd/bkw just a short distance.  The issue here is a gear problem...not hyd pump related.  HOWEVER...I also bet that the hyd pump and motor have...or have had...steel metal filings...from that broken bolt...get into the soft BRASS machined surfaces causing damage.  Inasmuch as you'll need to split the gearbox to repair the diff, it'd be a good time to rehad the ENTIRE hyd system...Pump and Motor.
  • Sad 1
Pullstart
If I haven’t already, :text-welcomeconfetti:  Sorry about your misfortune.  The fellas who have commented here can practically rebuild these transmissions blindfolded with both arms bound behind their backs...  they could help you along every step of the way :handgestures-thumbupright:
dcairns560
Thanks for the replies gentlemen.
Got the transaxle just about ready to pull out. Hope to have it apart tomorrow and figure out the issue
Achto
Following along to see what the out come is.
WHX??
:text-yeahthat:Sounds like Dan is preparing himself for possible D problems. :ychain:
  • Haha 1
pfrederi
If you have any questions please ask and let us know what you find.  Good Luck pulling the hubs they can be a bear.
D200 Hub pulling...
Edited by pfrederi
daveoman1966
While you have this D torn down, I'd urge you to examine the internals of the HYD MOTOR for damage or wear.  If you find wear or internal damage, it is likely that the Hyd Pump likewise suffers....since the Hyd Motor and Hyd Pump have common fluid (ATF), and that the soft brass internals are nearly identical.  Lastly, since the D is 45+, it is bound to need attention tot he Hyd Drive overall.
I have two .pdf files that I've developed to help you restore the Sundstrand power system. SUNDSTRAND Piston-Piston PUMP & MOTOR Refurb.pdf
D SERIES ALL LIST (3).pdf
dcairns560
Got the transaxle out and the case split apart about 3/4".  I can see a broken bolt laying down in the bottom.  Need to get a puller from work so I can get the hubs off and take it the rest of the way apart.
Is the case gasket available for purchase anymore?
daveoman1966
If you can get the cases halves far enough apart, reach in with a couple long box-end wrenches and remove the 3 or 4 remaining bolts holding the differential together.  With those bolts out, you completely separate the gearbox cases, then take the L/R axles to a hyd press to get the hubs off.
  • Excellent 2
pfrederi
Don't try a regular 3 jaw puller on those hubs unless they move easily. The hub flange is very thin compared to the length of the hub. Either pull from behind or as daveoman suggests take the differential apart to get the axle out then use a press.
Lowell at wheel horse parts and more has the case gasket you need. Absolutely do not use RTV little bits of that stuff can get into acceleration valves
https://wheelhorsepartsandmore.com/
dcairns560
Not having any luck getting the hubs off. I don’t see any bolts inside that I could remove. Do you happen to have an exploded view of the transaxle so I know what I’m looking for?
WHX??
Download that manual Paul has posted above. It has a IPL.
pfrederi
It isn't easy to get to them. but there they are.  I pulled my hubs (you only have to get one). Not easy but nothing working on a D series is...
dcairns560
Thanks for the additional pictures, I did download the manuals you shared earlier I just must have missed the section on the axle.
I got one of the hubs off... and destroyed it in the process :bitch:.   The rest of the bolts were not very tight either, and I can see where there was a crack in the bottom of the case that someone had "fixed" with jb weld :snooty:.    Luckily I have an identical parts tractor so  this evening I removed the transaxle from it.
Are these loose bolts a common occurence on these models?  Just wondering if I should pull the other axle apart to check them or just stick it in there and run it.
Im assuming that the washer in my picture goes where all the needle bearings go?
  • Sad 1
daveoman1966
This is the schematic from the Toro MPV.  Gearbox of the D-160.  The washer in your above pic is the THRUST WASHER (4-29B) and is on the short side of the 46-tooth gear (4-29A).  99R10005.gif
daveoman1966
For schematics, go to:  https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro
Enter D-160 as model, then clik SEARCH.  A model listing will appear...then clik thru the ASSEMBLY DRAWINGS for schematics of the tractor.
dcairns560
Thats an awesome resource, thanks!
pfrederi
I would open up the new transaxle and replace all the differential bolts with Grade 9.
pfrederi
You will need to replace the O rings and special washer between the manifold and hydro motor.  PM me your address I will send you a set...
