Herder 2,354 #1 Posted July 11, 2021 I've seen Expanding Foam used for many different things before but this was a first. Well I don't recommend you use it to repair a wheel. 1 1 Share this post Link to post Share on other sites
953 nut 56,236 #2 Posted July 11, 2021 Perhaps JB Weld would be more suitable. Share this post Link to post Share on other sites
Herder 2,354 #3 Posted July 11, 2021 3 minutes ago, 953 nut said: Perhaps JB Weld would be more suitable. Your on to something there!! Share this post Link to post Share on other sites
Jeff-C175 7,203 #4 Posted July 11, 2021 1 hour ago, Herder said: Expanding Foam Maybe it was actually polyurethane glue? Basically the same thing but doesn't expand as far. Still, wrong thing to use. I would go with the POR 15 SEALANT myself to patch the holes after prepping. https://por15.com/collections/all/products/patch https://por15.com/collections/all/products/stop-rust-kit 1 Share this post Link to post Share on other sites
Herder 2,354 #5 Posted July 11, 2021 1 hour ago, Jeff-C175 said: Maybe it was actually polyurethane glue? Basically the same thing but doesn't expand as far. Still, wrong thing to use. I would go with the POR 15 SEALANT myself to patch the holes after prepping. https://por15.com/collections/all/products/patch https://por15.com/collections/all/products/stop-rust-kit Lots of prep is needed!! The open cannel in the wheel had at one point sheet steel welded over it from the factory, I've seen them patched before but never filled in with foam. A lazy quick fix. 1 Share this post Link to post Share on other sites
ebinmaine 68,974 #6 Posted July 11, 2021 Well. I..... 1 Share this post Link to post Share on other sites
DennisThornton 4,769 #7 Posted October 16, 2021 UHF! Ultra high density/High strength foam! Used a lot by SpaceX and Blue Orgin! Share this post Link to post Share on other sites
