Jon925mn
Need deck spindle shaft
Jon925mn
Replacing bearings on 05-42MR02 deck spindle assembly and found this shaft with broken key slot. Anyone have a spare or know where to get one? Part # is 108849. 7" x 3/4.
roadapples
Try AtoZ in our vendor section...
Jeff-C175
5 hours ago, MNDIESEL said:
Anyone have a spare
I have one with the large nut on the bottom.  Message me if you're interested.
How's the pulley?
Edited by Jeff-C175
Goldnboy
Actually you do not have to use a woodruff key.
You can remove the key place a lock washer on top of pulley and fasten down
There is a service bulletin that explains this in more detail.
Jon925mn
Thank you Goldnboy for possible future information. I actually have a replacement being sent thanks to Jeff-C175. The shaft in picture is worn now and no longer serviceable.
Jeff-C175
Which is why I'm sending the pulley also.  I know you said the pulley is ok but wear like that makes me doubt that the pulley bore is not worn.
But I just thought of something... I think this pulley is from a 48" deck and the 42" deck might use a different one.  I know the shaft will work though.
Jon925mn
Yep. Checked and shaft is loose. Looks like 85mm on that pulley.
Jeff-C175
I hope the 42 uses the same pulley then!
Jon925mn
Diagrams list same for both decks. Thanks Jeff.
