WheelHorse520H
Wheel Horse Garage Floor
Jeff-C175
27 minutes ago, WheelHorse520H said:
a concrete slab
If  you do go with a slab, make sure to use a heavy plastic liner UNDER the slab and bring the liner up the sides in order to prevent the concrete from wicking moisture from the ground.
WheelHorse520H
… Otherwise I will have the same problem I do now. Smart, thanks for the tip.
rmaynard
3 hours ago, WheelHorse520H said:
Yes it is asphalt, but three of the four sides have doors although the dehumidifier is not a bad move after hearing what @rmaynard went through.
I wired in a bathroom vent. It uses very little electricity. However, a dehumidifier is like a reverse air conditioner. It will eat you alive in electric bills.
WheelHorse520H
That’s also true, I will see if I can find an energy efficient one but I will cross that bridge when I get to it.
