Jeff1129 108 #1 Posted July 3, 2021 I have a wheel horse 520hc im may rebuild the engine i dont know the engine has 1170 hrs Im just wanting to do a full restore and rebuild On it I'd like links Thanks,jeff Share this post Link to post Share on other sites
Handy Don 13,126 #2 Posted July 3, 2021 I've been completely satisfied with onanparts.com Others will be along with their experiences. 1 1 1 Share this post Link to post Share on other sites
520HC 208 #3 Posted July 4, 2021 yep onanparts.com 1 Share this post Link to post Share on other sites
onanparts.com 182 #4 Posted July 4, 2021 22 hours ago, Jeff1129 said: I have a wheel horse 520hc im may rebuild the engine i dont know the engine has 1170 hrs Im just wanting to do a full restore and rebuild On it I'd like links Thanks,jeff Hi Jeff, With 1170 hours your Onan is just broken in! That being said, due to age the gaskets and seals etc. are due for replacement. Your plan to go through the engine is perfect timing. Reset the clock to zero while everything is still in good shape is not expensive. It's called an overhaul or a refresh. You will find that all of the internal moving parts should be in good condition. You should not need to replace any major parts and spend big $$$. A top end job, new STD rings and clean up the valves and seats, replace all gaskets and seals. The end result will be a like new Onan that should provide thousands of hours of dependable service. If you are the original owner and have done regular maintenance since day one, then just a decarbon and fresh gaskets/seals is all that is needed. However, if you are not the original owner and service history is unknown, then a teardown/inspection would be the proper way to go as planned. FYI: We are going to be closed for vacation, not taking any orders July 8th through the first week of August. Working on our personal Onan projects and maybe get some fishing in too! I'll be updating our site shortly, today, with 4TH of July Holiday Sale pricing good until we close up Wednesday evening, the 7th. :) Shipping Dept will remain open after the 7th until all outstanding orders have been shipped. And most important! We do not have any CCC, Cheap China Crap! All parts are OEM Onan. :) 1 1 Share this post Link to post Share on other sites
