Bill Winn
Adjusting the Hydro!
Bill Winn
Good evening, so updates on my C175:
Parking brake now works, thanks Jeff-C175.
Replacement fender pan on the way, thanks Jeff-C175 and Lincoln
New hub set screws and seals on the way, thanks elcamino/wheelhorse et al.
New rear blade tach-o-matic mount on the way.
So here's the issue I looked at today when I got some free time...
When I got this tractor I noticed that it speeds up going down hill and the speed control lever does not stay in place on its own. I have to hold it in place or it will slow down significantly.
Is there an adjustment on the top of the hydro? I did read through Scotty's post about his hydro woes with his 416h so it reads like I may have a compound issue.... one with the speed control remaining set and the other with the downhill acceleration. Could it be as simple as a new belt and a tightening a bolt or nut?
I've included a lettered picture of the hydro linkage on top of the unit.
Bill
Jeff-C175
Bill, do you have the Sundstrand or the Eaton tranny?
@Bill Winn
Bill Winn
@Bill Winn
Dunno? How do I tell?
Jeff-C175
Is your filter on the right side or on the rear?
Also, if there's an S after the K in the model number it's a Sunny, if an E, an Eaton.
Edited by Jeff-C175
Bill Winn
Just went out to check. It's on the rear left.
JAinVA
Hydros will speed up going down hill. They shouldn't get crazy fast but they do speed up. Gradually tighten up nut D.  This adjustment will regulate the  speed setting. Under no circumstances put any lubricant  on this washer assembly. Luck,JAinVA
Bill Winn
Thanks and the VIN does have an E after the K. Is one brand better than the other?
JCM
I have 3 Eatons and they are bulletproof IMO. I know nothing about Sundstrands. Good luck
JAinVA
DSCF9104.JPG.2c3353204db0fc4d68d38319ddfcc95b.jpg.b9c5c3e41e652c97d89449fb320ab99f.jpgpost-14709-0-98425600-1424281457_thumb.jpgThe transaxle you have is an Eaton 1100. The Sunstrand  is a good transaxle but the Eaton might be easier to find if you need to replace the one you have. Like JCM I have several Eatons and have had no issues with any of them.
Edited by JAinVA
Jeff-C175
And likewise my Sundstrand keeps on tickin'
I think they're pretty much the same reliability wise.
gwest_ca
Click on the picture in the link
Garry
tom2p
as suggested above - tighten nut 'D'
you can also add an additional nut on top of the original nut ... (nylock or similar even better) ...
most (all ?) Eaton 1100 hydros will pick up speed as you head down a grade ... just tap the speed control lever lightly to reduce speed and stop the freewheeling
Eaton 1100 hydro is very durable / reliable
squonk
Check the piece under the plate at point B. That slot in the plate will wear a groove in it throwing off the adjustment.
Tuneup
What Squonk said! My 515 was so worn, there was no adjustment that would last. I bought a replacement plate and adjuster but the adjuster wouldn't run in the plate without my getting a grinder on that plate all around the travel surface - the plate coating catched on the nut. Quality isn't what it once was. I adjust it while standing behind the tractor, full throttle and warm.
Handy Don
With the wheels OFF THE GROUND, right?
Tuneup
Of course not :). I'm the type that has to get something in my eye before I wear safety glasses - an accident waiting to happen. I actually did just that adjustment today. The 516 did a nice job on the lawn today but the slowness of reverse is a bother. I pulled the plate and ground it a bit for more travel. You can get just a little before it hits the bracket. Put it in assumed neutral and started it at low idle. It crept forward. Nut adjust and done.
I do use jack stands and or ramps when under the Ford - have since a teen. My stupidity does have its bounds.
  • Haha 1
seuadr
i was picturing him running along behind :D
  • Haha 1
Jeff-C175
Mine doesn't. :auto-ambulance:
  • Sad 1
tom2p
  • Haha 2
Handy Don
11 minutes ago, tom2p said:
Applicant for Darwin Award....
  • Haha 1
Tuneup
C'mon, give him credit. He's got it almost to the balance point so there's not much on those 4x4s. 2x4s would have been sufficient. The man must be an engineer. That's not me, though. I have my limits.
  • Haha 1
Jeff-C175
Except for the fact that they are probably Balsa Wood!
Handy Don
Yep, I can see the engineer now..he pushes the wrench a bit too hard, the 4x4's drop to the ground and he's left balancing the car with his hands!
  • Haha 1
