Jeff1129
520hc led lights for halogen replacement
Jeff1129
I would like to convert halogen to led lights on my 520hc i would prefer Amazon links but anything works thanks
Jeff
Andy N.
For my '80's tractors listed in my signature, I used the following:
https://www.amazon.com/gp/product/B07R88B64W/ref=ppx_yo_dt_b_asin_title_o00_s02?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B00VT85Q0G/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
I mounted the tail lights with small bolt and nut and put a small loop connector on the ground and attached it under the nut.
Head lights were a direct replacement for me.
Handy Don
11 minutes ago, pfrederi said:
I put on a set of these. The beam is a bit more concentrated in the middle and throws a bit farther than the LED flood style. Also the 5000k is a bit less blue/white than the 6000k -- personally I prefer this.
Tuneup
5000K would be fun! Just remember that, in China, 2 years is the same as 2 months so your actual warranty performance may vary. What else is there nowadays? My 516 lamps are just dull - may do this as well.
peter lena
@Jeff1129, noting your planned lighting upgrade . since going after all my grounding areas , everything is better , this is an easy up grade you might try , first and last picture , the battery ground rail cable mount , and the lower engine mount to frame area. add a 4 ga  cable and connect those 2 points , also go over all your connections , do not be afraid to add a few other ground wires to anything that is not solid , dielectric grease on every bolt down .  just a suggestion , pete
Crazyredhorse
  • Like 3
  • Haha 1
