grasscuts
1993 520h back firing
grasscuts
Hi, here's what happened. I changed out 9 pin moles plug...had issues tracter quit running and changed the plugs while I was at it....got plugs from auto store cross reference to ngk they said it was the same heat range and I check electrod  length with calipers ,same...tracter started right up and ran great for about 10 min. And started back firing and quit.....going to check it out tonite anybody have an idea?
stevasaurus
Pull the plugs back out...what do they look like??  :eusa-think:
lynnmor
You should have NGK # TR4/3754 spark plugs.
grasscuts
great news, opened up the hood spark plug wire off......iI was thinking doom and gloom.....put the boot on and fired right up!  daaaaa but happy.  I have ngk tr5ix7397 plugs in now.. per the auto store. thats diff. from what your suggesting Lynnmor so I need to now whats correct.........champion   rs14yc  is whats in the owners manual please chime in tks guys
Chestnut
I installed the TR4/3754 plugs early this spring to replace a pair of the Champions. I was having hard starting problems and it starts much better with the NGK's, even though there were only a few hours on the plugs I took out. According to NGK's conversion chart the TR4 and Champion RS14 are the same heat range. TR5 is the next range colder. I don't have enough experience or knowledge to say how the Onan would respond to a colder plug. Most engines will tolerate one heat range up or down without issue. A hotter plug will burn off carbon better, and a colder plug will dissipate heat better. Something to be said for each with the Onan. They do build carbon, but the rear cylinder can also run hot. If it were mine and I'd already spent the $16 or so for a couple of Iridium plugs, I'd run them for mowing but make sure I ran full throttle. For snowblowing or other winter work I might switch back to the hotter plug.
The ix designates a modern fine-wire Iridium tip plug. The TR4/3754 and the Champion are old fashioned copper core plugs.
https://www.ngk.com/ngk-7397-tr5ix-iridium-ix-spark-plug
https://www.ngk.com/heat-range-conversion-chart-2
  • Similar Content
    • WheelPuke
      By WheelPuke
      I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
      I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
    • BrianKoch
      By BrianKoch
      Hello gentleman,
      Problem: will not crank on its own, will crank with jump box—but still not fire
      Recent things I did prior to this issue: cleaned fuel filter, replaced battery cables, replaced cable from ignition to starter
      I have my test light out and am probing around.
      There is no power at ignition/magneto wire or the ignition/starter wire
      There is power everywhere else
    • Jeff-C175
      By Jeff-C175
      Detailed wiring from the Demystification Guide #492-4509
      4 pages 1.4MB Color
      p7-67 to p7-70
      Onan powered
      1989 416-8 model 31-16O801
    • trident
      By trident
      Need some help. My 800 Special has an electric PTO. It is not working. Checked Ohms - nothing. My questions are 1) how does the PTO come off and 2) can they be rebuilt? I took the bolt out that I thought holds it on but no luck. Must be something more?
    • jakester
      By jakester
      hello all I'm a new owner of a 312-8 tractor, have starting problems, came across a very small, what I believe is a relay between the battery and the dash,its about 2/3rd size of a cube of sugar silver on the outside blue on top with a hole bout the size of a pea, theres 6 pins with wires connected to it on the bottom do not know what this is any thoughts? I cannot determine the exact year of this machine for there is no tag anywhere only tag on engine kohler magnum md #m12s   ser# 170370459  spec#  471527  I figure its mid to late 80s to early 90s. of all the wiring diagrams ive looked at it does not show any thing like what I just described also can that little circuit board be removed that's like a test point for idiot lights? any help would be appreciated  jeff
