pond195520032003
1974 D-200
pond195520032003
This is my 1974 Wheel Horse D-200 with a 20hp twin cylinder Kohler, rear pto, turning brakes, 3pt hitch, ag tires all around, weights all around and a 54" snow/dozer blade! also have a rear finish mower, reat roto tiller, and a Didier 50" sickle bar!
rickv1957
1974 NOS D200 With NOS Ark 550 loader
rickv1957
  • Heart 1
chrisd200(inactive)
I am the 2nd owner of this tractor. Bought it off of the original owner (who was my neighbor) in 2001. Has a 48" belly mower, 50" tiller, 60" rear mower, plow, wheel weights, and Brinly sleeve hitch adapter. Hours are unknown cause the hour meter stopped working years before I bought the tractor. The current meter shows 860 hours. Kohler K532 Engine has never been gone into but the hydro pump was rebuilt about 3 years ago. The rear end has been gone into twice. Great tractor!!!!!!!!
post-9665-0-65529300-1362445650_thumb.jp
  • Like 4
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Finally getting around to working on my ark loader.  The previous owner said he thinks the problem is with the spool valve.
      As I've learned a bit more about hydraulics now, I'd like to get this all sorted out.
      I noticed the power beyond port is connected to the reservoir return.  Is that right?
      Anyone see anything blatantly incorrect?
    • ccs002
      By ccs002
      Looking for a complete hydro pump for a D-160. Tractor is missing everything from the rubber coupler disc back. Also willing to buy a complete tractor for parts, the closer to Harrisonburg VA the better. Thank you.
    • tractorboy79
      By tractorboy79
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
