Similar Content
By bigbuck
I'm not positive of the model, but I think I'm close. Please call George at 517-499-5678
By Travas
Hello everone reading this. Im currently in the process of building a race mower out of a front engine 8-32 toro. It was sitting outside for the longest time because of a broken axle. It believe it has a vertiical 8 hp b&s that had running. Here is some some photos of it. I put a bifferent transaxle in because it was spare one laying around. I put it on and it fits pretty well. Altho i had to remove all the clutch and shifter parts to get it in, but hey it works. I got a wheel on and tried getting the other off the axle it was on. So i put it in the press and tried for about a half hour before in popped loose. After that it took me about 15 mins and got it off. It was really rusted on there! Put it on the transaxle to how it fits and looks. Now im in the process of drilling a hole the axle for the key in the wheels. Any suggestions or ideas? I will update this project when do some more work on it.
By kurm
You can search for the specs but here are some links:
https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro&lang=us_en
https://lookup3.toro.com/partdex/modlinfo.cfm?xCaller=Toro&o=2&x=22004&b=9900001&e=9999999&m=73552&y=1999&n=523Dxi Garden Tractor&channel=CN
https://lookup3.toro.com/partdex/modlatch.cfm?xCaller=Toro&x=22004
This is a beast! Comes with the 60" deck and also a 48" deck and a new battery. New belt (installed but unused), newer hoses, regular maintenance.
There are wheel weights too but idk if they fit this unit as I've never tried.
758 hours
I got a zero turn and a Kubota tractor and this has sadly become ignored.
By JoeM
Seen this old Toro on CL the other day. Bad rear end $125. Seems pretty cool.
By justin77
Hello,
I’m looking for some guidance to repair my right side hub. It started leaking the other day after mowing, I’ve noticed a gap on the leaking side between the hub and trans axle housing. I’m thinking I may just need a thrust washer and or possibly an oil seal? I’ve read that I may need to fab a hub puller? See attached photo. Any help or advice is greatly appericiated!
