Aldon
Double pulley on discharge side for bagger
Aldon
Does anyone know what the part number is for the double pulley on discharge side of the 48 inch deck? I bought a used bagger set up that I want to retrofit to go on my C160's 48 inch deck. The only part obviously not provided was the drive pulley for the bagger which is a double pulley set up on the right side or te one next to the discharge chute.
Jeff-C175
I don't know the answer, but I wonder if it's the same pulley as the center?  If it is, I might be able to fix you up if you have the keyed 3/4" shaft spindles.  IM me if you're interested and we'll talk.
Aldon
Im assuming its the same. but not sure.
Jeff-C175
I can't think why it would not be the same...  of course you won't be able to run the belt/pulley cover on that side.  Does the bagger attachment come with a belt cover to replace the existing one?
I've not seen a belt driven bagger for a WH, is this something that WH sold as an attachment?  or aftermarket?
You said your machine is a '78 so I presume that you've got the 3/4" keyed spindle shafts?
Jeff-C175
It appears that the second pulley is a bit smaller than the primary pulley.  This is from a thread here by @cleat from 2016
