76c12091520h
106368 Idler Arm Assembly
76c12091520h
 Now available: 106368 Idler arm assemblies, as found on many 70's thru 90's hydro equipped Horses. Discontinued by Toro. Manufactured by us to be an exact , no hassle replacement.  Price is $40.00 each
Edited by 76c12091520h
Handy Don
Are you also sourcing the unusual flanged bushing (9/16" OD x 1/2" ID) that goes on the belt side of the shaft? (#51 in the diagram)
Will it have the closer-to-the-shaft pulley mounting hole for models with the larger idler pulley and no drive-disengage clutch?
Edited by Handy Don
76c12091520h
#7879 (51 in the diagram ) is still available from Toro
