Brockport Bill
42 inch RD mower on 520 HC ??
Brockport Bill
on the Interchangability chart it shows a 42 inch rear discharge # 0542mr04 fitting a 520HC -- but a few years later after 88-89 of course, the 520HC isn't listed - so my question is.... the 90's mower version of 42 inch RD is model 78355 - does that fit to a 520 HC ?  I assume same carriage assembly - but not sure about the mule ?? thanks
Brockport Bill
as clarification -- i see the chart shows 78350 as distinguished from the 78355  - first is apparently a standard RD and the other is recycler RD - don't understand how that would change the assembly carriage adaptability to HC -- especially since it lists the H as a fit?
squonk
Should fit fine.
Handy Don
:text-yeahthat:
gwest_ca
Should work
Mower DNA
1976 model 65-42MR01 replaced by - (Has the flat spindle belt idler pulley mounted on a triangular plate.) - (Has multi-link hardware at the gauge wheel support)
1977 model 75-42MR01 - Both use blades with 5/8" x 3/4" double-D center hole unless the spindles have been upgraded. (Has the flat spindle belt idler pulley mounted on a triangular plate) - (Has multi-link hardware at the gauge wheel support)
These all use blades with 3/4" center hole.
1977 model 75-42MR02 replaced by - (Has the flat spindle belt idler pulley mounted on a flat bar) (Has multi-link hardware at the gauge wheel support)
1978 model 85-42MR01 - (Has the flat spindle belt idler pulley mounted on a flat bar) (Has multi-link hardware at the gauge wheel support)
1979 model 95-42MR01 - No ipl available
1979 model 95-42MR02 - (Has no multi-link hardware at the gauge wheel support)
1980-1983 model 05-42MR01
1984 model 05-42MR02 - Last year for bearings with 3/4" ID
1985 model 05-42MR03 - First year for bearings with 17mm ID unless older spindles were updated.
1986-1988 model 05-42MR04
1989-1990 model 15-42RC01
1990-1992 model 15-42RC02
1993-2012 model 78350
Note - 17mm is .669"
Garry
Brockport Bill
Garry  -- you said should work -- on a 78355 on a HC ??????????
gwest_ca
A 78350 is a replacement for the 15-42RC01.
A 78355 is a 78350 with a 86001 recycler kit added.
You can download the 1988 Attachment list here
Garry
Brockport Bill
 Terrific -- thanks -- A+ help as always
