Searcher60 209 #1 Posted June 5, 2021 Hello everybody! My 69’ Electro K301 starter drive is worn slam out. On occasion it wedges itself in the flywheel and locks up the engine and starter. The only thing wrong is the gear. There ain’t much of it left. I do not see any replacement drives. The reviews for the $50 replacement starter are not good at all. Any ideas other than a used one which may also have issues? Thanks! Share this post Link to post Share on other sites
WHX?? 49,924 #2 Posted June 5, 2021 Try here Kohler Starter Rebuild Kit | Kohler Starter Solenoid | PSEP.biz 3 Share this post Link to post Share on other sites
daveoman1966 3,768 #3 Posted June 5, 2021 Is that the starter with the rather odd looking aluminum mounting bracket attached to it? If so, I have 2 of them in working order. Will find a copuple pics and post them in a lttle while. 1 Share this post Link to post Share on other sites
oliver2-44 10,079 #4 Posted June 6, 2021 (edited) 4 hours ago, WHX24 said: Try here Kohler Starter Rebuild Kit | Kohler Starter Solenoid | PSEP.biz make sure you get the gear with the same number of teeth. Also check if you need to replace the very front starter bearing or the one in the front cover. The rear one seem to last almost forever. Edited June 6, 2021 by oliver2-44 1 Share this post Link to post Share on other sites
Searcher60 209 #5 Posted June 6, 2021 4 hours ago, daveoman1966 said: Is that the starter with the rather odd looking aluminum mounting bracket attached to it? If so, I have 2 of them in working order. Will find a copuple pics and post them in a lttle while. No aluminum, has the steel mounting plate with the special type bolts. Standard K301. Drive may be the same? Thanks! Share this post Link to post Share on other sites
Searcher60 209 #6 Posted June 13, 2021 On 6/5/2021 at 4:18 PM, WHX24 said: Try here Kohler Starter Rebuild Kit | Kohler Starter Solenoid | PSEP.biz Here is a picture of my 1969 K301 starter. I am missing the piece that the starter drive in that link needs to work. The piece goes on the front plate of the starter, and the new style drive backs into it when it retracts. Not sure you know the piece that wasn’t used on the older starters. Share this post Link to post Share on other sites
