3Horses 10 #1 Posted June 5, 2021 (edited) Hello, Can someone please try to help me out. My 95 520h is having battery charging issues. The new voltage regulator I put in has 12.4 volts on all 3 spades Is this normal. Also I keep blowing the 15 amp fuse. I have put new ignition coils in, new voltage regulator, checked wires etc. I really need help figuring this one out. Plus the battery gauge is pegged to the RIGHT. Thanks, Jake Edited June 5, 2021 by 3Horses added content Share this post Link to post Share on other sites
953 nut 55,320 #2 Posted June 5, 2021 Sounds like you have a bad voltage regulator or some of your wires going to it are shorted together. Remove the terminal from the regulator, turn on the key and see what the voltage on each wire is. Share this post Link to post Share on other sites
3Horses 10 #3 Posted June 5, 2021 Richard, Which terminal do I remove. Share this post Link to post Share on other sites
3Horses 10 #4 Posted June 5, 2021 Oh I got it. Remove all 3 and check the wires themselves. Ok I'm going to try. 1 Share this post Link to post Share on other sites
3Horses 10 #6 Posted June 5, 2021 Oh I got it. Remove all 3 and check the wires themselves. Ok I'm going to try. Thank you for the diagram. This is a big help. 2 Share this post Link to post Share on other sites
