Chris1055 106 #1 Posted June 5, 2021 I’m trying to hunt down the 6449 seal for a hydro gear. I found the Napa 11124 but it’s is 1/4 width where I need a 1/2 will the 1/4 inch work or where can I find the 1/2 through skf thanks Share this post Link to post Share on other sites
Maxwell-8 4,366 #2 Posted June 5, 2021 4 hours ago, Chris1055 said: I’m trying to hunt down the 6449 seal for a hydro gear. I found the Napa 11124 but it’s is 1/4 width where I need a 1/2 will the 1/4 inch work or where can I find the 1/2 through skf thanks I need two as well. I am gone order them at the Toro dealer. No to expensive here that way. Share this post Link to post Share on other sites
ebinmaine 69,710 #3 Posted June 5, 2021 5 hours ago, Chris1055 said: I’m trying to hunt down the 6449 seal for a hydro gear. I found the Napa 11124 but it’s is 1/4 width where I need a 1/2 will the 1/4 inch work or where can I find the 1/2 through skf thanks A site search on the 6449 shows it crosses to the 11124 and is the correct Axle seal for the 1-1/8" axle hydro transmission. Width shouldn't be an issue. 1 1 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,176 #4 Posted June 5, 2021 SKF 11124 is in the middle. Other seal types and widths they have. CRWA1 is the type/style of seal. Letter at the end identifies the lip type - R=Nitrile. One advantage of using different width seals is it allows you to install in a different location on the shaft if the shaft is worn or damaged by rust. 1.125 1.624 1.628 0.25 11123** CRW1 R 1.125 1.624 1.628 0.25 11111* CRW1 P 1.125 1.624 1.628 0.25 11130** HM21 R 1.125 1.624 1.628 0.256 11134* CRWA1 V 1.125 1.624 1.628 0.256 11133* CRW1 V 1.125 1.624 1.628 0.256 11124* CRWA1 R 1.125 1.624 1.628 0.256 562487* CRWA1 H 1.125 1.624 1.628 0.256 547585* CRWA1 H 1.125 1.624 1.628 0.256 547488* CRWA1 D 1.125 1.625 1.628 0.315 542621** CRWHA R 1 1 Share this post Link to post Share on other sites
953 nut 56,741 #5 Posted June 5, 2021 You can get the real thing on for$ 9.34 a pair shipped free. https://www.ebay.com/itm/142042768245 1 1 Share this post Link to post Share on other sites
Chris1055 106 #6 Posted June 5, 2021 Thanks didn’t even think to check eBay Share this post Link to post Share on other sites
