Paul Adanick
My first Wheel Horse (Lawn Ranger) restoration
troutbum70
I think it looks pretty good just as it sits, a wash and wax and it will be parade ready. A very nice find.
kpinnc
I agree, it looks great like it is!
But, if you are going to restore it, you've definitely got a solid candidate!
Ed Kennell
It looks like it has been restored making it a  good candidate for a re-restoration.  I would be hesitant to restore an original  finish tractor.
rjg854
I like Ed's way of thinking, if your tractor  "IS"  original, save it as is, it's only original once.
Paul Adanick
I also would be hesitant to restore an original finish tractor, but no, much of the paint certainly isn't original. I suppose from the angle of the photo, the tractor does look great!
It seems that the previous owner liked to "touch things up"...unfortunately, he used some paint that didn't match or adhere well, didn't mask things off and
did some rather poor repairs. Not really a restoration.
I would like to put this machine back to original condition (or something as close as I can)…I'll even leave the "factory" weld spatter I'm finding.
On some items I'm not sure how far to take the restoration: for example the "Quadrant- Lift" plate (Item 6, part number 5538). The notches are worn from years of use...do I weld them up and mill them back out or leave them as they are? They still work fine.
dclarke
That looks like a nice one to restore, you'll find lots of help here should you need it. I'll be following along.
Terry at "redoyourhorse.com" makes all the decals for your Ranger and does excellent work.
Pullstart
:text-welcomeconfetti:  I think with your reasoning, you’re doing the right thing.  As for the loft mechanism... do what makes you happy.  Nobody gets rich on resale... so make it the way you want it and have fun. :handgestures-thumbupright:
  • Excellent 3
The only thing I’d do to it would be to change that gas cap
  • Haha 2
pfrederi
You may also find that that #62 (5551)Plunger Lift lever is worn where it engages the quadrant.  Father bolted a plate on the quadrant to fix it.  (He didn't weld)  after I inherited it i put some weld on the plunger to fill in the wear.
  Father bought the L-107 in May 67.  $469.95.  Been in use by him or me ever since.  She is my chore tractor use year round. So much easier to get on and off than her big brothers...Take care of the front tires that pattern/size is NLA.  Your rears are not original.
Like this
Terry M
Looks like a nice tractor!!   The implement lift lever on the 65-68 lawn rangers originally were chrome.    I’m guessing yours was just painted.
Ed Kennell
IMO, while you are doing it,  repair or replace all worn parts.      :twocents-02cents:
I like them with a bit of patina, but with excellent mechanicals.  Your Lawn Ranger looks better than mine
Edited by 305
Add picture
Paul Adanick
Thanks for the head's up.  It appears that my quadrant had "extra slots" added by the previous owner (I have found a replacement).  It also appears that my plunger is badly worn, but I only have the drawing in the manual to go by. Would it be possible to get a picture of the plunger engaged in the quadrant?
Paul Adanick
Thanks!  I'll work on locating a gas cap.  That plastic one doesn't even screw on properly.
Paul Adanick
So I stripped the paint and found the remaining chrome.  I need to decide whether to etch the old chrome and paint or have it re-chromed.
Paul Adanick
I have an order in with Terry for chassis and engine decals. I realize now that I forgot to order the mower deck decal set.
I also just saw that you own my "next" Wheel Horse I want to restore...the '60 Suburban 400...would you mind sharing some photo's?
Lee1977
I think it's all original those Good Year Tires look new.  Don't think they were sold after the 70's.
pfrederi
The original rears on my L-107 are Turf-Savers and say Wheel Horse....
dclarke
Here’s the Suburban but I no longer have it. I sold it a while back to make room for this ‘56 RJ, I’m finishing it up now.
pfrederi
  Complete with Father's bolt on fix from the mid 80s
Paul Adanick
Absolutely beautiful. Do you sandblast before paint?
Paul Adanick
It looks like you've welded up an area similar to mine.
Terry M
See if the chrome is still in half decent shape....if it is,try to see if it’s possible to remove the remaining  paint without damaging the chrome.   Then try polishing it with some very fine steel wool.    This worked well for me.
Having stuff re-chromed is very expensive!!!
