69DEZ
Updated Picks
69DEZ
Let's see if I do this right. Mounted new comfy seat, wheel spinner and front wheel weights.
69DEZ
HA who says swearing at this *^$#(&^$ doesn't work!!!! :P:( Well it paid off. It works!! Now if I can just figure out what the hell I did :D
combatmp29r
Yep looks like you did it right :P Lookin good. I see the elusive handle mounts for the plow now :D I do have a set of the missing parts here somewhere. It may be quicker for me to make a set though :( Oh your ID tag should be behind your custom guages. I stress should :(
nylyon
Perfect! Great job :D
Sparky
That has to be the biggest muffler I have ever seen on a vertical. Can we assume its whisper quiet :D ?
Mike....
69DEZ
Thanks for the encouragement guys. :D Joel I 'll check for tag under the gauges, thanks. I'll have to look again and see what I have for the plow parts. I'll get back to ya. Believe it or not, after cutting grass for 3 hrs my ears ring. I had a 1250 CC never bothered me but the WH does. I use ear plugs. Now I'll have to mount a beverage holder on this thing before spring. :P
69DEZ
Combat I checked for the ID tag your were right 1969. Thanks! :D
chevelletown
I like the custom gauges, what do they monitor? One has got to be voltage what else? :D
Stigian
Cheers for taking the time (and swearing :P ) to get your photo's posted Dez (having an educated guess at your name here :D
The question is, what do all them there gauges do?
As chevelletown say one must be voltage so whats the others for?
Am i to guess that by the looks on your dogs face, its not too keen on WH's?
combatmp29r
No no 69DEz its more like this
Kidding just kidding :D:P
I've owned about 9 of the 69s V8s anyhow over the years. You've owned yours longer though. My first Wheel horse was the 69 Commando V8 thats now the V18. Got it 12 years ago well guess its 13 now. Never turned back since.
T-Mo
Good job on posting the pictures. Man that's a comfy looking seat. :D
69DEZ
HOLY COW!!! Just got home from work. I'd say we have about 4" of snow with another 4"-6" by tonight. Looks like I'm going to get some seat time when I wake up this afternoon!! :D:( I bought the seat at Northern tool. I think with shipping it came to 51.00. Not a bad deal. It even says Toro on it. Gauges, Volts, amps and oil pressure. They all worked, or should I say they all registered at one time. I was running the wire for my spot light and cut the oil line by accident. To many cocktails :P It's the set of Suntune gauges that you would get at an auto parts store. My buddy hook then up for me as kinda a joke, kinda to go with the flames. :( Did I mention that I'm going to get some seat time today?????
69DEZ
The dog is upset...... No thumbs to grip the steering wheel :D
WheelHorse_of_course
Yeah, I had noticed him too. Probably is just skeptical about horses infringing his territory.
I have the same set of gauges, ready to be mounted in the same spot. I started out with amps, temp and oil pressure and have replaced the temp and oil with hours and volts.
With both volts and amps you have on-board the equipment to fully monitor and diagnose nearly any charging system problem. :D
Stigian
The dog is upset...... No thumbs to grip the steering wheel :P
Train him to use his teeth :(
But make sure he cleans the dribble off the wheel afterwards :D:( :(
nylyon
Dogs don't drive tractors silly..... They do the trimming....
oldandred
Great job like the seat one could fall asleep when pushing snow.
Now the only thing it needs is white wall tires ?? :D:P :(
combatmp29r
Wheel time?????? Good for you :D I could probably get some wheel time with the WH pump right now. Here I have 4" of standing water out side the shop, and most of the back yard. Hmmm maybe its time for a WH boat :P:( :(
combatmp29r
Hmmm I posted and totally skipped what I originally intended to post :D
John how does your rear weight bracket attach???? Just at the 4 bolts for the rear hitch, or does it reach farthur forward?? :P
kpinnc
Great pic Karl. My yellow lab hates anything with an engine on it. I think she'd get her lips ripped off if I brought out the trimmer and her at the same time!
And my chocolate lab is just a retard...
Didn't mean to hijack! :thumbs:
Kevin
