TJ5208
Bigger tubes
TJ5208
Can I put bigger tubes in smaller tires like 23 10 50 12 or 23 8 50 12
daveoman1966
Depends...  if the tube is too big, it'll be forced to fold in some places.  That fold MAY cause stress, leading to leaking.
A couple sizes one way or the other otter be ok.  You'll  only know at the first FUBAR.
  • Excellent 1
roadapples
I'd sooner have tubes a little small than large...
pacer
This is almost guaranteed to happen!!
I worked on ground equipment many years for Delta Airlines and with 20+ baggage carts and belt loaders and ..... well, a bunch of things with tires. The bag carts were the worst, they ran 5.70x8 and I quickly found that the reason I was having so many flats was because the 5.70x8 tubes were getting folds in the tubes which would soon split. I decided to try using 4.00x8 tubes and never had that problem again. Since then I use at least one size smaller tube in my horses.
Heh, was astonishing how many flats ALL the equipment would get, along with surprisingly fast wear - youd think running around an airport with concrete everywhere that wouldnt be the case, but I changed quite a few over the years:wacko:
  • Thanks 1
Pullstart
I knew someone would share this story, but couldn’t for the life of me remember who’s it was.  Sorry ‘bout that :handgestures-thumbupright:  I think about your experiences every time I tube a tire!
