ondeadlin
Fully engaging PTO stalls engine - thoughts?
ondeadlin
Spent much of last weekend working with my C-160 and the tiller.  Worked like a champ.  Left the tiller on, because I knew I had more tilling to do this weekend.
Checked the trans before I started her up today, was a little low, so I added some oil. Took the seat and the fender off to do it. Put 'em back on, turned over right away, sounded great.  Used the hydro to raise the tiller.  Got in position, but as soon as I went to fully engage the PTO for the tiller, she stalls.  Doesn't lose power or start to stall or make any problematic sounds until right at the end, when it sputters and stalls.
-- Runs great in forward and reverse, full power, no issues
-- Hydro runs as it should
-- Tiller turns as it should if the PTO is partially engaged, no signs of any issue there.
-- There do not seem to be any belt issues, too tight, etc.  Same setup as last week.
Any thoughts anyone has would be appreciated.
Edited by ondeadlin
gwest_ca
Seat switch hooked back up? Or switch may not be closing. It powers the ignition with pto ON with a Kohler engine.
Garry
  • Like 6
ondeadlin
I did reconnect the seat switch, but maybe I should check to see if it's fully engaged.  That's a good thought, thanks.
I would have thought it would have prevented me from moving at all, though, no?
Edited by ondeadlin
Jeff-C175
I don't believe so.  The seat switch is only 'active' when the PTO is engaged as I recall.
@ondeadlin
Edited by Jeff-C175
  • Like 6
kpinnc
Not sure of your model engine, but does it have a condenser?
The PTO switches and seat switch interlocks would definitely be a good place to start too.
953 nut
:WRS:
Your seat switch is only in play while the PTO is fully engaged.
Lee1977
The plastic button on my 520 seat switch was so worn that if I shifted in the seat It would stop the engine.
Ed Kennell
There's your clue to solving this problem.
Jeff-C175
In cases such as this it's always the last thing you touched.
ondeadlin
You gentlemen have again steered me right.  Thank you all.
Went out this morning, took the seat switch apart, cleaned the contacts on both sides, put it back together right, and that did it.
Thank you all! I'm now off for more tilling!
  • Excellent 3
AMC RULES
:wwp:  :text-coolphotos:
ondeadlin
Pictures! As requested ...
Used the tiller and the belly blade to remove a lawn of weeds this weekend, and then laid sod.
  • Excellent 3
OutdoorEnvy
Wow!  Killer view!  That is really pretty.  I hope that wood walk way goes down to a walleye catching machine :thumbs:
Handy Don
If the weeds were thriving and not scraped off for discard elsewhere, you may have just tilled in all their seeds and "planted" them under the sod. :huh:
it may take a year or so, but probably "they'll be back".
Very inviting spot with a terrific view. Lake Michigan?
Edited by Handy Don
ondeadlin
Thanks! That's Lake Huron in the background and where we are the wave action is too strong for anyone to have a dock.  I get out there in the canoe once in a while, though, and there's decent fishing right off the shore.
And I do love that view.  Even as I was raking (and raking and raking) this weekend, I was feeling lucky to be doing it with that view.
Edited by ondeadlin
ondeadlin
I did work pretty hard to scrape/rake and discard the vast majority of the old "lawn."  Which was a PITA, of course, but ... yeah, you're right, it'll be the better move long-term.
It's Lake Huron, off Michigan's thumb.  We've got a little three-season A-frame that's just behind that lawn, old school 50-foot wide lot, long and narrow.
Edited by ondeadlin
  • Excellent 2
