matzopie 0 #1 Posted May 24, 2021 ARE BOTH FRONT IDLER PULLYS THE V TYPE? I HAVE HEARD THAT ONE IS AND THE OTHER IS FLAT. DECK # 0537SC01 Share this post Link to post Share on other sites
Jeff-C175 7,203 #2 Posted May 24, 2021 1 minute ago, matzopie said: ARE BOTH FRONT IDLER PULLYS THE V TYPE? I HAVE HEARD THAT ONE IS AND THE OTHER IS FLAT. DECK # 0537SC01 If you're talking about the pulleys on the 'mule drive' at the front by the right front wheel, one is a VEE and the other is FLAT. Share this post Link to post Share on other sites
rlrnot 39 #3 Posted May 24, 2021 (edited) The idler pulleys (part no. 111170) on the 05-37SC01 deck are both vee pulleys. ALSO, this deck uses belt no. 111178, which is a 6 sided belt, which means BOTH pulleys on the mule drive are vee pulleys as well. The confusion arises because I believe there is a 37" deck (possibly 05-37SC02) that uses a conventional belt (3 sided) and consequently the pulley configuration changes for the idler and mule on that deck. I have the 05-37SC01 deck and the idlers and the mule drive pulleys are vees. Edited May 24, 2021 by rlrnot 2 1 Share this post Link to post Share on other sites
PbFlinger 64 #4 Posted May 24, 2021 The forward idlers on mine are both flat. Mine uses the conventional V belt. 1 Share this post Link to post Share on other sites
PbFlinger 64 #5 Posted May 24, 2021 I don’t know which part number my deck is, all of the information is gone off of it. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,176 #6 Posted May 24, 2021 2 hours ago, PbFlinger said: I don’t know which part number my deck is, all of the information is gone off of it. If you have some flat idlers it is model 05-37SC02 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,176 #7 Posted May 24, 2021 3 hours ago, matzopie said: ARE BOTH FRONT IDLER PULLYS THE V TYPE? I HAVE HEARD THAT ONE IS AND THE OTHER IS FLAT. DECK # 0537SC01 05-37SC01 has all V-pulleys and uses a 6-sided belt. It could be changed to like the 05-37SC02 with some flat idlers and use a 4-sided regular belt. The front idler assembly in this case has one flat idler and one V-idler. Share this post Link to post Share on other sites
Brockport Bill 1,778 #8 Posted May 25, 2021 i have 1989 - ......37 inch Side Discharge model # 05-37SC01 -- here are two profile photos if that is any help Share this post Link to post Share on other sites
Brockport Bill 1,778 #9 Posted May 25, 2021 as noted above,,,,,,, i have always used belt # 111178 Share this post Link to post Share on other sites
manahale 43 #10 Posted September 15, 2024 very nice job Bill. Share this post Link to post Share on other sites
