Maxwell-8 4,366 #1 Posted May 21, 2021 I have a old lawnmower 5speed gearbox, mainly used on rear engine-mowers It's for in a project, It has a belt input, and chain output but I have no clue what type chain it uses. Had a 420 sprocket but that wasn't the right one. Any help is appreciated! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,173 #2 Posted May 21, 2021 See if this helps https://www.mcmaster.com/chain/ansi-roller-chain-and-links-10/ Garry 1 Share this post Link to post Share on other sites
peter lena 8,967 #3 Posted May 22, 2021 @Maxwell-8 link should have a number on it like # 40 , or similar , most critical on chains is the correct lubrication , like OPEN GEAR , OR SPECIFIC CHAIN LUBRICANT , that has an anti fling rating to its use, makes chains and the related steel gearing really stand up . should be easy to look up , pete 1 Share this post Link to post Share on other sites
