Maxwell-8
So yesterday I picked-up a C175. She was rusting away as she was stored outside. She had a new to her Kohler K341. @squonk The previous owner indeed better had"LET AN ELECTRICIAN      CHECK his  SHORTS!"  as bad wiring shorted the battery out, and exploded/melted. She has a Sundstrand hydro pump with a Filter, is that normal? By the pump I believe it's a 1980. But you never now for sure as it's made in Oevel. Due to the bad wiring, the engine was in no running condition. But don't think the K341 has many hours on it. The hydro I don't know if it works. She was hard to push. So i lift up one wheel, so we could roll here one one wheel and the diff prevented the trans from locking up.
So first things to do:
1) get the engine running
2) replace the steering wheel, but don't think removing it will be very hard as it's already split in two.
3) replace the axleseals, the oil leak caused a lot of sandbuild up as she was mainly used on for leveling out a horse track.
4) clean all the acid and remove all the old wiring to do a full rewiring
5) replace the plastic seat pan with a metal.
6)...
I'm looking forward on my first C.
It's also my first hydro, I don't know a lot about them and prefer actual gears. Simpler and need less maintenance (parts-shortage).
But since I couldn't find another project WH and me hearing a lot of good things about hydro's  on the forum..  I finally took the shot.
Edited by Maxwell-8
  • Like 5
  • Excellent 1
squonk
Sunstrand with a filter should make it a piston- piston version. Make sure you use correct filter. Wix 51410 or Napa1410 or equivalent.
Letting the genie out of the wiring is the quickest way to find the bad spot! :lol:
  • Thanks 1
WHX??
Looks pretty rough Max but we've seen guy's start off with much worse. Yes pull that fender pan off & get the crud cleaned off around the transmission. After her bath pull the drain plug and filter as Mike suggested.
  • Excellent 1
Handy Don
16 minutes ago, Maxwell-8 said:
But since i couldn't find another project WH and me hearing a lot of good things here on the forum..  I finally took the shot.
Looks like you have your work cut out for you on this one to overcome the rust, abuse, and neglect. As long as the important bits are sound (engine, transmission, steering, etc.) I'm sure you will get a satisfying result. Wishing you the best of luck!
  • Thanks 1
SylvanLakeWH
Love the Black Hoods!!! :ph34r:
Looking forward to your progress…!
  • Thanks 1
roadapples
Did you see a sundstrand tag? I thought these had Eaton 1100. Where's the filter?
bds1984
As longs as the engine is free, she'll run.  My C165 was in similar if not worse shape when I decided to give her a refresh almost 7 years ago.  The K341/M16 is one of the best engines Wheel Horse used (best single cylinder)!
  • Excellent 1
Maxwell-8
I saw the sundstrand tag on it, And if tractordata is correct they used the sundstrand in the 1980 year. The filter is right below the pump on the transaxle.
I didn't knew that sundstrands came with filters, thought only the eatons 1100 came with it. But it's built in Belgium so anything is possible as they build Wheel Horses with the parts they got from the US, and that could vary from time to time.
Edited by Maxwell-8
WheelhorseBob
Sundstrand shave filters, both of my c161’s have filters. 1978 and 1979 vintage. Good luck I’ll follow along!
  • Thanks 1
pfrederi
Sunstrand Filter on the right side Eaton Left Rear...
Maxwell-8
Yep, on the front right side. a Pretty big filter (for European standards :lol:)
Damien Walker
Hello, I have a C175 (Eaton) which I rebuilt many years ago from scrap yard condition and it was pretty much in the same state as yours. After many hours of hard work, it is probably already time for a respray! I'm sure yours will smarten up just fine. The original Kohler 17HP twin had thrown a rod, smashing a hole in the crankcase and whilst I did manage to repair it, welding the crankcase was very difficult and I never quite solved the cracking on cooling issue. The consequence was that it had a permanent oil leak. I eventually replaced the engine with an M17 which has given excellent service (other than throwing the generator magnets off the flywheel).
Your biggest problem will be the plastic rear fender and it would probably be best to fit a steel one from either an earlier C series or from a 3,4,500 model. I did take a mould from mine but I am not confident I could finish this off and produce fibre glass copies from it..let me know if you are interested though and I could have a look at it.
  • Excellent 2
Maxwell-8
Bought me a parts Wheel Horse 300 sereis half a year ago,  so I have a steel fender for it. Would be a cool idea, remaking them with fiber glass, heck I may try it myself as we do have some experiences on boats.
Edited by Maxwell-8
  • Like 3
Maxwell-8
Any tips on cleaning up the acid? Or just yank all the old cables out and power-wash the crap out of it.
  • Excellent 1
Damien Walker
Power washing should do the trick but any problem will be in the joints between panels so probably best to strip down. A thorough soaking in washing soda (ie a mild alkali) would neutralise any acid too. Though mild, washing soda is probably not good for the new paint soagain a thorough power wash would be necessary. Bon chance!
  • Thanks 1
Pullstart
As Damien mentioned, you should find a way to neutralize the acid :handgestures-thumbupright:
  • Thanks 1
953 nut
:text-yeahthat:          Looks like anything reused would end up giving you trouble in the future.
  • Thanks 1
Damien Walker
Yes, anything that has suffered water or acid attack might turn out to be a reliability hazard. My C121 is still on it's original wiring but it has been dry stored for the last twenty years or so. My 518H however was badly neglected by the po and took a lot of effort to resolve. It suffered corroded and broken connectors, a malfunctioning ignition switch and rusted up microswitches all due to water ingress. If in doubt, replace!
Maxwell-8
Got 'Amy' on an dolly so I can move her around the shop. because that hydro is impossible to push around.
So I took her outside to deal with the battery acid.  Got some soda crystals in hot water to neutralize the acid  and after that I power-washed the crap out of it.
Edited by Maxwell-8
  • Excellent 1
WHX??
Should be a tow valve on it.
  • Thanks 1
Maxwell-8
I took out all the old wiring and sprayed some starting fluid just to see if the K341 would fire up.
Let me tell you, we Europeans are not used to such a big displacement per cylinder. She fired right up and for the spilt second she fired, it sounded awesome!
Kohler baby! :handgestures-thumbupright:  :music-headbanger:
  • Like 3
  • Thanks 1
WHX??
Be careful with the sniffing salts  not too much. It can wash the cylinder walls. Instructions to open the tow valve are on the sticker in the lower right of the pic. Good luck reading it tho. Heck of place for a sticker that gets rubbed off!
  • Thanks 1
Maxwell-8
I know, but thanks for the reminder, would naphtha be better?
Haha, indeed, can't read a thing on it.
WHX??
I got chastised once for trying to get a motor running on it but have since just switched  to carb & choke cleaner to get those fuel pumps primed.
  • Thanks 1
oliver2-44
I just use gas in a hand pump oil can
  • Like 3
  • Similar Content
    • Thatoneguy
      By Thatoneguy
      So I washed my rear end and sundstrand 90-1136 and now the by pass valves leaks when I screw it in past a certain point.  If I screw it all the way in I can sit there and watch the fluid start seeping past it.   I changed the o-ring with an R-04 i believe is what it was.   Do these require some sort of thread sealer? There was nothing on it when I took it out, and when I used the valve to push the tractor in my shop it worked fine and has never leaked. Any ideas would be wonderful!
    • D_Mac
      By D_Mac
      Well fellas I may be going to the dark side. Going to look at one tomorrow. You know the story, ran a couple years ago when parked. Now no spark. Has mower deck with new blades and belt. Tires have new tubes. Has the plastic rear fenders/ seat pan that's busted up. I have no experience with the kohler twin. I know you like pictures but don't have any. Any helpful suggestions on what I need to look at tomorrow? Any idea what a replacement metal seat pan / rear fender unit will run? Worth ? I'd like to save it but really don't have the room for another but that's never stopped me before. Like to hear all your input. Thanks
    • mattd860
      By mattd860
      I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
      The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
      Here is a link where you can download the installation manual: CLICK HERE
      I am selling these kits for $330 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
      Thanks!
    • olivertractor
      By olivertractor
      I was pulling a roller and thatch rake the other day with my c120 hydro and noticed oil on the back of the fender. On looking closer I saw the plug thing on the back of the pump leaking oil. Any advice on how serious this will be to repair? Anything helps
    • Bill D
      By Bill D
      I bought this K341 and was wondering what it came on originally.  It's a 13 fin block and has been bored .020 over already.  It has a Kohler carb which may not be original.  Bill
