Ifixoldjunk
busted tie rod, heavy duty replacements?
Ifixoldjunk
So I was out mowing the other day with my 310-8 and somehow snagged my wheel in a hole in the yard. Anyways I pretty much destroyed my ball joints. I've since replaced the tie rod with junkyard parts but I was wondering if anyone's found a heavy duty aftermarket replacement for the tie rod assembly.:confusion-helpsos:
Like would generic adjustable go-kart tie rods do the trick?
8ntruck
Heim ends from McMaster Carr.
Look up @ebinmaine thread on Colossus in the restoration and customs section of the forum.  He built a set of heavy duty tie rods.
Might be hard to find, because he hasn't updated it in a while.  EB - seems like we are due for an update?  :teasing-poke:
  • Haha 2
roadapples
@Ed Kennell made his own also...
Crazyredhorse
ebinmaine
@8ntruck yes I did make up a couple big rugged rods for mine.
Works good.
@Ifixoldjunk
I can look up and send you a link later.
I used *** 7/16 double male tie rods.
I went one size up because the strength difference is huge.
You need to drill out the tie rod mounting holes obviously. BUT that works out well in most situations because a LOT of the Wheelhorse steering holes are slightly oblong/egged.
@Crazyredhorse I bought a set of those rods off the flea bay.
There many sellers.
The ones I got were not even close to drilled straight and used end joints that were already a little loose at new.
IMHO it's best to stick with a known vendor such as our own Wheelhorsepartsandmore.com.
The price is right and the quality is excellent.
I agree. I'll see if I can get some time put into it this weekend.
peter lena
@Ifixoldjunk , been using female heim joints with stud or open type for years , https://www.amazon.com/Steel-Inch-Female-Joint-Studs/dp/B07XVPBYR9  , thread is 3/8x24 so just pick up some threaded rod at your local h/w store . unless you want to go the regular part route , they are easily available all over the net , never had one fail or break , makes a quick easy fix , pete
Ed Kennell
I used the Mc Carr 7/16" greasable Heims and 7/16" bolts and rod.    No issues at all.
102_3003.JPG.3ba989ea3358bd436545a3948f05a168.JPG102_3004.JPG.bc5c2e636f3541e55b82532b31556af6.JPG
Edited by Ed Kennell
  • Excellent 2
  • Similar Content
    • rustyedge1
      By rustyedge1
      Going to need tie rods, one of mine came apart today. Was wondering if anyone could recommend someone ?
      Would settle for good used parts if available from someone. Dose anyone know the part numbers for my machine.
      Thanks in advance for the help.
      Dan
    • OHLB
      By OHLB
      Newbie here. 310-8 won't start. Battery is dated 10/19. Did crank a couple times but started losing ummph. Should I replace it or attempt to charge it? Can't tell if the battery is frozen. Never knew until today that batteries could freeze and that it's dangerous to charge a frozen battery. It's been single digits with wind chill the last couple weeks here.
    • Big Rig
      By Big Rig
      ISO clutch neutral safety switch for 310-8
      or alternative
    • Rob R
      By Rob R
      Soo couple of years back did a pulley change on the tranny from 6 inch to 4.5 and used a 1/2 X 79 belt to make it work and it worked fairly well but wanted to get back to a 5/8 drive belt so went to a 5/8 x 81 inch belt and added a second flat Idler pulley. I simply cannot believe how smooth and sharp it shifts and drives now!  The added flat Idler was 2 3/4" with a 5/8ths bore used and existing hole on the side shroud and just opened it up a bit. I use to slip a bit on steep hill with the 79" slips no more, the belt drives and the clutch is  LOT smoother and in the right pedal area.... Will see how it holds up cut 3/4 of an acre of grass yesterday NO issues.
    • Ifixoldjunk
      By Ifixoldjunk
      so I spent a few hours today welding up a custom front weight bracket for my 310-8. It has two and a half inches of ground clearance with a generic 12 inch weight bolted on.
      so the question is, how well do y’all think the 300 series front axle will hold the weight? It’s only 50lbs so it’s lighter than the snowblower it has to hold up in winter so I don’t think I’ll have any problems. And I really don’t intend on using it constantly.
