FBaggshorses
Gas tank Petcock grommet re-install
FBaggshorses
In an attempt to remove the fuel line from the petcock on the bottom of my gas tank on a C-120 I inadvertently pulled the entire grommet out of the bottom of the tank spewing gas everywhere. Yes, in hindsight  I should've emptied the tank but figured closing the petcock would be suffice...
Wrong!  What a mess.. had gasoline everywhere.
Anyhow my question is:
Is it necessary to use  a sealant on the grommet prior to re-installing it back into the bottom of the gas tank?
Oh and advise very appreciated thanks in advance.
bc.gold
No sealant required., Install the grommet first then the petcock, liquid soap helps.
Edited by bc.gold
  • Like 5
roadapples
Don't  use a grommet over. You can get a new grommet and shut off for 10 to 15 dollars...
  • Like 7
Maxwell-8
ebinmaine
Agreed.
The rubber is very likely hardened and formed to the position it used to be in.
  • Like 8
ranger
Yes to this. One thing, did the grommet come out in one piece, or did it break, there may still be part of it inside the tank. I have always found gas a good lube for rubber suspension bushes etc, it evaporates quickly, grease doesn’t.
SylvanLakeWH
Vendor on this site - wheelhorsepartsandmore.com sells them.
I just installed one few days ago.
Easy.
  • Excellent 2
Maxwell-8
Like Dino mentioned in my topic, always use a lubricant when installing.It's easier to install but mainly easier on the grommet.
Achto
Check your local hardware or small engine shop. There is a good chance that they have those tank grommets on hand. They were used by many company's.
The Tuul Crib
I use wd 40 . What little you use
will mix in with gas!
:text-welcomeconfetti:T😎:rs:
:happy-jumpeveryone::happy-jumpeveryone::wwp:
Primeline part # 7-07461
available from Oreilly or Napa for about 3 bucks
Jeff-C175
:text-yeahthat:
peter lena
@FBaggshorses,  use a DIELECTRIC GREASE ON THAT GROMET , made for rubber to metal use , also try to get a  straight installation push into the tank hole , for easiest fit , pete
johnnymag3
What Pete said....
       perfect for install, and preservation of exposed rubber !!!
clueless
If it's the original grommet that make it at least 44 years old, buy a new one with the valve, cheap fix, might make it another 40+years. Since the tank is empty remove it, simple, and rinse it out with a little soap and warm water, lay it upside down in the sun for awhile, with both holes open it won't take long to dry and the sun will help soften up the tank. Take the valve and put a little lubricant on it, preferably petroleum based, I use a little 3in1 oil, I use the s**t on everything #OLDSCHOOL, now push the valve half way into the grommet now put a small amount of the lubricant on the end of the grommet. Start the grommet in to the tank, once it's started push the valve in and it all slides in, easy peesy. Old Wheel horse mechanic show me this, works every time.
Edited by clueless
  • Like 5
FBaggshorses
Wow ok, alot of good knowledge there .Thanks alot greatly appreciated
bc.gold
Every abandoned farm house had at least one tin.
Jeff-C175
I must live in an abandoned farm house then!  Maybe 3 or 4 !  I've even got a couple cans of Singer Sewing Machine Oil!
  • Similar Content
    • Team70R
      By Team70R
      Pulled the cord on my HH60 tonight and it made a hellacious noise resulting in the cord pulling alllll the way out.... And staying out. Got an electric starter sitting on my junk H60... Will it work!!?? Or should I rebuild the pull start?
